258+2100 what to do with Valve cover breathers? - JeepForum.com
post #1 of 5 Old 02-08-2010, 10:34 AM Thread Starter
deezil
I recently swapped a 2100 onto my 1985 with the 258.
I also put a Aluminum valve cover on at the same time.
I am using a open element air filter and it of course doesn't have provisions to plumb the pcv and breather line back into the air intake like the stock air cleaner did.
I have one small port under the air filter flange on the carb and even though I would have to choke it down the pcv should be ok there right?
What to do with the vent on the tail end of the valve cover?
Show me some pics of your setups with the 2100 as well. I'd like to see where you routed everything.
Thanks!
deezil is offline
post #2 of 5 Old 02-08-2010, 11:58 AM
I6CJ7
The front pcv hose will go to that fitting on the carb as you described as thats where the carb draws the air out of the valvecover. The rear is a breather allowing air into the valvecover. You'll need to put a little filter or breather into that rear hole to filter the incoming air. Then you should be all good.
I6CJ7 is offline
post #3 of 5 Old 02-08-2010, 12:19 PM
VACJ7
VACJ7's Avatar
I thought I had a good pic but can't find it right now. The PCV should be connected to manifold vacuum. I tap into the port near my brake booster. The breather I connect to the port just under the air horn in the back. This supplies filtered air to the crankcase.
VACJ7 is offline
post #4 of 5 Old 02-09-2010, 07:47 PM
afgd1
had rebuilt engine got new valve cover alum type front line is air breather off hose so line has angle on it hose is about 6 1/2 inches put breather on ens of it breathers great also oil flows back into valve cover not pretty but works great
afgd1 is offline
post #5 of 5 Old 02-24-2010, 06:19 AM
sgttaylor83CJ7
1983 CJ7
I bought a little crankcase breather from Pep Boys for 13 bucks. It fit snuggly into the rubber grommet on top of the valve cover. I installed it in the front hole as my pcv line runs to the carb from the rear hole...
I would really appreciate the groups opinion on this. It was my solution to the previous owner running the carb fuel bowl vent into the valve cover.
It seemed silly to vent gas fumes from the carb into the valve cover, only to pull them out of the other end and send them back to the carb...
Brand: Spectre Proformance
Part Number: 3995
Cost: $13
sgttaylor83CJ7 is offline
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
PCV Valve location/Valve cover replacement jobst Jeep CJ Forum 2 03-28-2010 01:53 PM
PCV valve and leaking valve cover hole crrushing Jeep CJ Forum 2 02-08-2010 05:44 AM
Power valve block off motorcraft 2100 for extreme rockcrawling Axlesnap Jeep CJ Forum 2 03-20-2009 10:21 AM
Name of 1 way valve on end of drivetrain breathers/ place to buy? supraman1990 Jeep CJ Forum 2 10-25-2008 09:13 PM
