250 dizzy - JeepForum.com
post #1 of 7 Old 07-07-2011, 07:38 AM Thread Starter
copauls863
1982 CJ7
250 dizzy
Anyone do this whole 250HEI distributor swap? I read somewhere it works, you just need to swap the gears. Anyone know of a good write up on it?
copauls863 is offline
post #2 of 7 Old 07-07-2011, 07:40 AM
JeepHammer
Running On Empty...
1973 CJ5
Nothing to it, just change gears, use a V-8 gear, and plug it in.
The gears are the tricky part, some of the gears on the market a not high quality and sometimes cause problems.
Getting a V-8 gear through the dealership will keep you from getting one of the poor quality import gears.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 7 Old 07-08-2011, 07:06 PM Thread Starter
copauls863
1982 CJ7
Like same year jeep 360 gear? is it the exact same gear?
/edit: 304 i mean haha
would the one of of my 258 dis. work on the 250 one?
post #4 of 7 Old 07-08-2011, 07:54 PM
JeepHammer
Running On Empty...
1973 CJ5
Yup, AMC V-8 gear they are all the same.
Takes a 'V-8' gear to fit the shaft, I-6 gears are too small of a center hole.
V-8 gear on the I-6 GM HEI distributor will work, no problems.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #5 of 7 Old 07-08-2011, 08:00 PM Thread Starter
copauls863
1982 CJ7
cool man other than that i just have a +/- on the module connector right?
assuming that, i would just need to tap the - for the tach signal on my tbi?
and then the negative goes to ground? + i assume i can tap a wire from the old module?
also, ur the man, man
post #6 of 7 Old 07-08-2011, 10:44 PM
JeepHammer
Running On Empty...
1973 CJ5
You didn't say a thing about TBI...
Depending on the TBI you are using, you will need a GM HEI 7 pin module, fits right in where the standard 4 pin modules comes out...
Power wire comes through the ignition switch, 'Run' position (NOT the 'Accessory' position) and out to the 'BAT' connector terminal on the side of the distributor cap.
Your tach will depend on what tach you are running.
If it's a factory tach, Ignition switch, through tach, out to distributor.
If it's an aftermarket tach, then you should have instructions, usually a 'Green' wire out to the Negative terminal marked 'Tach' on the cap connector.
One is most aftermarket tachs are voltage signal triggered, meaning it counts the number of times the coil turn 'On' and 'Off',
The factory tach is a CURRENT triggered tach, and it has to run in series in the ignition source line.
Stupid way to do things, but this is AMC after all... Save them 5 cents on the extra wire.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #7 of 7 Old 07-09-2011, 10:58 AM Thread Starter
copauls863
1982 CJ7
I dont have a tach but i know the tbi has a wire hooked to the - on the coil, else it wouldnt run.
it is running a gm tbi, through howell. now its just sounding like too much work, the only reason i wanted to do it was to move everything to one unit and eliminate as many wires as possible..
so how would you wire the dis to work with the 7 pin put in it?
DUI Dizzy or Teamrush + MSD? mtbtweety Jeep CJ Forum 77 02-16-2013 10:38 AM
SBC350 dizzy 3S00W Jeep CJ Forum 14 05-07-2010 06:12 AM
Dizzy Gear tgarey Jeep CJ Forum 7 10-18-2009 01:25 PM
oil comming out of dizzy. Axlesnap Jeep CJ Forum 12 03-27-2009 05:52 PM
