232 number one has lazy exhaust valve - JeepForum.com
post #1 of 6 Old 07-06-2013, 09:57 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
I have a 1975 dj5 (I know you cj guys know the i6) the engine was missing under load but idles perfectly, I took off the oil cap and see the 1's exhaust rocker is barely budging. So I removed the valve cover and all the push rods are turning. There's a tad of a ticking in the motor, I was told it had a flat cam
jeepdj5 is offline
post #2 of 6 Old 07-07-2013, 05:45 AM
gmakra
You was probably told correct. Time for a need cam, lifters, timing chain and while the head is off a valve job.
gmakra is offline
post #3 of 6 Old 07-07-2013, 09:27 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
Ok well I just wanted to make sure it's not a common easy fix. What's a good cam to put in it? If your not aware a dj5 is a 2wd right hand drive mail truck cj5 chassis.
jeepdj5 is offline
post #4 of 6 Old 07-07-2013, 05:36 PM
gmakra
Stick wit the stock cam Melling is a good brand and not pricey.
gmakra is offline
post #5 of 6 Old 07-07-2013, 06:40 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
Yup going to recam and rering her and slap it back together
jeepdj5 is offline
post #6 of 6 Old 07-07-2013, 06:43 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
And a head job
jeepdj5 is offline
