Quantcast 232 interchange with 258? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 232 interchange with 258?
Old 01-31-2007, 06:50 PM   #1
high51977
I am still witing for snow to melt so I can find my jeep, but in the meantime I am trying to gather info. My main priority is frame, suspension, body in that order. I also have issues with the engine. I need an exhaust manifold as mine is broken in half. I want to upgrade the distributor, and the intake manifold as well. my question is this: will any of these things interchange between the 232 and the 258? I am eventually going to swap it out for a small block Ford but don't think funds will allow at this time and I want to get out camping at least once before summer is over.
high51977 is offline   Reply With Quote
Old 01-31-2007, 06:55 PM   #2
qf4phlyer
qf4phlyer's Avatar
I had a 232 in a 79 CJ-7. I think the intake will be interchangeable as well as the exhaust manifold. I bought the thing used and thought it was a 258 for years until a crank bearing went, the shop didn't realize it until they put the crank in and found the journals were to big.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline   Reply With Quote
Old 01-31-2007, 07:25 PM   #3
whit450
1977 CJ5
I did the same swap but went with the 4.0 head. Not sure of the intake will work but I think most later 258's had a 2 barrel carb. the motor is a straight drop in and will bolt up to your t-150
whit450 is offline   Reply With Quote
Old 02-01-2007, 10:54 AM   #4
JackN77CJ7
Stupid question. How do you know the difference? It would be nice to know what I have in there.
JackN77CJ7 is offline   Reply With Quote
Glock Forum
