232 i6 timing & tune up specs - JeepForum.com
post #1 of 3 Old 02-05-2014, 12:45 AM Thread Starter
sierraimage
1975 CJ5
I wanted input on additional timing adjustments on the 232.
I was just going to set it to 5 degrees and be done with it.
Would any other adjustments really improve the tune of the engine at this point? Meaning, do I need to do any type of advancing etc. or can I just set my guns advance dial to 0 and set the timing to 5 degrees on the marks?...after I ensure points/dwell readings are accurate.
The FSM comment of "initial timing" is was got me thinking about this. What would be after initial timing?
I have the specs from FSM as:
5 degrees initial timing @700 rpm
31-34 cam dwell
points .016
sp gap .033 to .037
Thanks
sierraimage is offline
post #2 of 3 Old 02-05-2014, 06:41 AM
swatson454
1983 CJ7
First off, I've never even seen one of those engines so take this with a grain of salt. Having said that, I've never seen an engine run worth a crap at 5*. That's old, emissions stuff and there tends to be some real improvements in idle quality and throttle response with just a few more degrees. 10* is certainly worth a try.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #3 of 3 Old 02-05-2014, 08:40 AM
hp_lovecraft
1981 CJ5
My 232 is set at 10 degrees. That's as far as I can go without a ping. Runs great, though it has an HEI
hp_lovecraft is offline
