225 buick - JeepForum.com
post #1 of 8 Old 06-03-2009, 05:01 PM Thread Starter
newjeepinidaho
1966 CJ5
225 buick
curiouse i was given a buick skylark with a v-6 in it it has a electronic ignition a/c delco hi the motors look the same will it work in my 66 cj-5 with a 225 oddfire
newjeepinidaho is offline
post #2 of 8 Old 06-03-2009, 05:14 PM Thread Starter
newjeepinidaho
1966 CJ5
ok well as far as i know the spec on the jeep say 225 but i am new to this it is in a 66 cj-5 and i was told from po that motor has been rebuld but not changed so if i take his word for it that what i have but i don't know how can i identify the motor the easiest everything look the same on the skylark So is it a direct swap or will there be modifications to make it work
post #3 of 8 Old 06-03-2009, 05:16 PM
Mudweiserjeep
Mudweiserjeep's Avatar
1970 CJ5
The Dauntless (Buick) 225ci V6 was an option for CJ-5 from 1965 thru 1971. Was and still is a great little motor. From factory producing 160 Hp and had alot of torque due to a heavy flywheel.
Go to www.earlycj5.com for more info. An excellent source for the info your looking for.
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
Mudweiserjeep is offline
post #4 of 8 Old 06-03-2009, 05:20 PM
Mudweiserjeep
1970 CJ5
I should add that I had the Dauntless in mine until it needed rebuilt. I found a 231 for $100 so I swapped it out. When I get some extra cash I am going to find another Dauntless. I really liked the motor.
The motor your looking at.....is it odd fire or even fire? Mine was a even fire...so I had to have the flywheel balanced. Other than that it bolted right up.
Tim - KC8UXU
1970 CJ5
231 V6
post #5 of 8 Old 06-03-2009, 05:26 PM Thread Starter
newjeepinidaho
1966 CJ5
i don't want to change the motor it has the 225 but so it must be a even fire because the buick i am looking at has the same firing order i just was wanting to convert the ignition over to the one out of the skylark and hoping it will work
post #6 of 8 Old 06-03-2009, 05:50 PM
Mudweiserjeep
1970 CJ5
The 225 is a odd fire and will have the same firing order.
You can upgrade the ignition to the HEI distributor. It is a good upgrade. Infact you can convert a even fire distributor to a odd fire. Just do a google seach. If you need any help just drop me a line.
Tim - KC8UXU
1970 CJ5
231 V6
post #7 of 8 Old 06-03-2009, 09:41 PM
my-jeep-earl
1971 CJ5
You never said what year the skylark was, Buick changed from Odd Fire to Even Fire mid 1976. If it's a front wheel drive, don't even fool with it as the motor mounts on the block are relocated and won't fit unless your a great frabricator!
my-jeep-earl is offline
post #8 of 8 Old 06-04-2009, 12:10 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'm thinking he is just wanting to swap distributors for the ignition upgrade...
Rick
Cutlass327 is offline
Value of buick 225 v6? snowrider81 Jeep CJ Forum 4 07-01-2009 07:54 AM
Buick 215 Paul_TT Jeep CJ Forum 2 10-23-2007 09:16 AM
Buick 350 in CJ 95% Complete Jeff5886 Jeep CJ Forum 2 09-29-2007 03:42 PM
258 Swap to Buick 350 Jeff5886 Jeep CJ Forum 10 07-30-2007 04:06 PM
GM Dex-Cool in a Buick 225? FILDO Jeep CJ Forum 4 07-06-2007 11:24 PM
