21 gallon MTS gas tank - JeepForum.com
post #1 of 4 Old 07-09-2011, 02:26 PM Thread Starter
redcj576
1979 CJ7
Hey everyone, with the new 350 engine and a 4 bbl performance carb. Stock 15 gallon gas tank is not enough for me . i found the 21 gallon MTS gas tanks for the CJs but they are not steel , they are made of polyetylene . İ âm not sure how tough they are.so any experience on the polyetylene gas tanks ?
CJ5 Project finally finished...
'77 CJ7 -.GM 305,T176,4.10s,37x14.5 Creepy Crawlers
'79 CJ7- 350,TH400,NP205,4.88s,39.5" Creepy Crawlers
'61 Chevy Apache 10-all stock
'90 Chevy K1500 4x4 Truck-LT265/75R16 BFG All terrains
redcj576 is offline
post #2 of 4 Old 07-09-2011, 05:33 PM
jarbidge09
I have had one for about 7yrs and no problems no more rust and if it rubs on rock/tree root it has some give it will not dent like metal.
jarbidge09 is offline
post #3 of 4 Old 07-10-2011, 03:25 AM Thread Starter
redcj576
1979 CJ7
i believe MTS gas tanks are made in USA. i found one on ebay for about $250. Also there is one more made by Omix for about $480. why is that difference? İ dont believe in Omix quality.
redcj576 is offline
post #4 of 4 Old 07-10-2011, 03:50 PM
h2ojeep
1978 CJ7
I think the MTS tanks are superior to the OEM. No rust, and because they are flexible, would probably be better than the metal.
Anything that would knock a hole in the Poly tank would also knock a hole in a metal tank.
I have had a couple of MTS tanks. The 21 actually gave me a 23 gallons (include lines and filler line). They fit with no alternations, however the bracket that extends the tank down did rub against the differential cover on occasion.
The guys at MTS are also very helpful if you need to call.
I would have no problem recommending a MTS tank.
h2ojeep is offline
