2015 winter project - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 2015 winter project
Unread 12-18-2015, 05:38 PM   #1
station10fd
2015 winter project
This years winter project is going to be a refresh of most of the suspension parts up front.
[IMG][/IMG]
5 years ago I installed an old man emu lift. I went with the cs014F springs up front because at the time I just had the 4 banger and stock bumper. It rode perfect and was level front to back. Since then, I've added and SBC and a much heavier bumper. The front has started to sag with the extra weight. I've ordered two CS036R springs for the front which should level things back up.
[IMG][/IMG]
Also planning on putting the rugged ridge heavy tie rods in using the goferit bushings on a tie rod flip.
[IMG][/IMG]
Also replacing the ball joints to hopefully give back my return to center steering problems I've always had. Most will have to wait till after Christmas before the wife will release parts to me including a powder coating kit and oven. So I'll just start by dismantling some stuff.
[IMG][/IMG]
station10fd is offline   Reply With Quote Quick reply to this message
Unread 12-18-2015, 06:57 PM   #2
Jim1611
Jim1611's Avatar
I want to see more pictures without the cover! Nice!!
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 12:36 AM   #3
RedNeckCorvette
1979 CJ7
Yupp - She is a Beauty
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 12:25 PM   #4
station10fd
I'll be glad to pull the cover off and take a few jeep porn shots
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
It's come a little ways since pulling it home 6 years ago.
[IMG][/IMG]
I pulled my air dryer off the wall and emptied the desiccant from the tube and baked them for a couple of hours to bring back the nice deep blue. I hear powder coating likes nice dry air.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
My lovely wife comes out to the garage and says "hey, what are those new looking things?".....she found the new drag link and tie rods, she took them away to wrap....looks like I'll spend the week cleaning the engine bay up.
Unread 12-19-2015, 08:40 PM   #5
RedNeckCorvette
1979 CJ7
Do you have any pervatures with the rear wheels off?
RN
Unread 12-19-2015, 09:08 PM   #6
rixcj
rixcj's Avatar
1979 CJ5
Originally Posted by RedNeckCorvette View Post
Do you have any pirvatures with the rear wheels off?
RN
That's funny! You were being funny, right?
station10fd...that's a beautiful Jeep! I tip my hat to you!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 10:40 PM   #7
roadhog304
1973 CJ5
What a beautiful Jeep. Not sure what you are going to clean under the hood
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline   Reply With Quote Quick reply to this message
Unread 12-26-2015, 06:31 PM   #8
station10fd
The Wife released all the goodies, so time to get to work. I started on one side getting things dismantled.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Got a couple parts cleaned up
[IMG][/IMG]
First try at powdercoating
[IMG][/IMG]
Unread 12-27-2015, 06:35 AM   #9
rixcj
rixcj's Avatar
1979 CJ5
Looks like you're doing a nice job!
What is the picture of the of with the "silver" steering knuckle? Is that just wire brushed shiny, pre-powdercoat? It doesn't look bead blasted....looks too shiny for that...
Rich
Unread 12-27-2015, 08:03 AM   #10
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Nice work. What are you baking the parts in?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2015, 08:10 AM   #11
Jcowart62
1979 CJ7
You definitely have your work cut out on that engine compartment, great looking jeep
Jcowart62 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2015, 09:51 AM   #12
station10fd
Rich
Yes, that is the knuckle after blasting. Santa brought me a blaster cabinet. I'm using black diamond fine. Still learning how to use it. I'm having some clogging issues, maybe I need a better water separator.
[IMG][/IMG]
Santa also brought this little oven for my powder coating.
[IMG][/IMG]
I would love to have a full size oven in the garage, but I'm flat out of room.
Unread 12-27-2015, 10:08 AM   #13
y2k-fxst
1964 CJ6
Bigger parts you might have to do in the house oven when the boss is not home. Found that having a pot roast ready to go in with lots of onions helps to mask the smell and/or appease the boss when she gets home!
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline   Reply With Quote Quick reply to this message
Unread 12-27-2015, 10:46 PM   #14
station10fd
Did a little work on the axle shaft tonight since we're snowed in.
[IMG][/IMG]
[IMG][/IMG]
New ujoint and powder coat
[IMG][/IMG]
Enlarged holes in the knuckle to 3/4 inch for the goferit bushings
[IMG][/IMG]
[IMG][/IMG]
I've read on other tie rod flip threads that Keith said using this on the bushings is just as good as welding
[IMG][/IMG]
Unread 12-27-2015, 11:22 PM   #15
y2k-fxst
1964 CJ6
[IMG][/IMG]
As long as the shoulders are on top of the arm there should not be any problem, unless they come out when you replace tie-rod ends and are seized to the taper. That Loc-Tite retainer stuff is good, just never use it on anything you might want to take apart again. But, you might want to throw an extra bushing in your trail kit if your luck is as good as mine though!
