2000 Jeep Wrangler dies at idle frequently - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 2000 Jeep Wrangler dies at idle frequently
6th Annual, Beat Your Wife to the Credit Card Sale!50 in light bar /A pillar mount less than 500 at JeepHut.cFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-26-2014, 05:28 PM   #1
mustangjeep
I have a 2000 Jeep Wrangler 4.0L with 5spd. My Jeep will miss occasionally. It will die at idle frequently. Usually, it will start right back up. It will sometimes give P0340 code.
I have replaced my cam position sensor. I have replaced my crank position sensor. I have replaced my alternator. I replaced the IAC. I cleaned the throttle body. I sent my ECM off to SIA electronics to have it checked. I replaced the throttle position sensor.
The fuel pressure was checked.
I'm scratching my head what else that it could be.
mustangjeep is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 05:47 PM   #2
numbersix
1979 CJ5
Still throwing the p0340 code after a new cam & crank sensor? Could be wiring or failing ECM.
1979 CJ-5, mostly stock.
2001 XJ, DD / offroad.
numbersix is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 07:09 PM   #3
mustangjeep
SIA electronics tested my ECM and it passed their testing.
Unread 11-26-2014, 08:35 PM   #4
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I almost thought I was reading the wrong forum
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
