20 Gal Poly Tank Strap - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 20 Gal Poly Tank Strap
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 04-26-2015, 11:35 AM   #1
ccincrco
Hi all!
New to the forum. Just bought my father-in-law's 86 CJ-7 and am going through a checklist of things he never bothered to fix. The factory, 20gal poly tank has a leak that is evident when the tank is full. I pulled the tank and found the leak. In addition to repairing the leak, I was going to pull it out of the shell to clean it up and the strap bolt broke snapped off as I was removing it. So, aside from figuring out the fix for the leak, my problem is I can't seem to find a replacement strap online that doesn't reference just the 15gal tank. Does anyone have any recommendations or know of a strap that will work for the 20gal factory tank? Any suggestions on a fix for the leak would be helpful too. (I've heard 3m 5200 is a good option.)
Thanks!!
ccincrco is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 02:05 PM   #2
only in a jeep cj
I've only been able to find used 20 gallon oem straps.
When I had a strap end break, I removed what was left of the threaded section with a grinder, beveled the end, and welded a new threaded section (from a bolt) on to replace what broke off. Worked great.
Remove the tank from the shell, clean out all the mud and clean off the rubber sheets (power washer works great) and make the drain holes bigger and add more. Paint the inside of the shell too.
Find the crack (probably at the top from the strap being over tightened) and use a hot iron like a soider tip to swirl and plastic weld the crack back. Then scuff up the area and coat with epoxy to further seal it. Online boating places or marine store should have what you need
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 02:34 PM   #3
ccincrco
Thanks for your help! I ordered something online that looks close so we'll see. Unfortunately I don't weld either - looks like now might be a good time to learn!
Unread 04-26-2015, 05:53 PM   #4
thirstybob
I have a complete 20 gal. poly tank set up with sending unit I removed from mine. I live in Aurora and I'd let it go cheap.
thirstybob is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 06:05 PM   #5
ccincrco
You may have saved the day! How much you looking to get for it? I could pick it up whenever.
Unread 04-26-2015, 06:44 PM   #6
thirstybob
How about $75
You can reach me @ 303-919-7464 if you're interested.
Unread Yesterday, 12:02 PM   #7
ccincrco
I appreciate the offer. I tried to stop the strap I ordered but they already processed it. Since that's all I need (and I'm cheap - haha!) and I think I have the leak solved, I'm going to see if that works and if not, I'll hit you up to see if you still have it.
Unread Yesterday, 12:06 PM   #8
thirstybob
Unread Yesterday, 01:35 PM   #9
texasdave
texasdave's Avatar
1980 CJ7
MTS should have the strap.
texasdave is offline   Reply With Quote Quick reply to this message
