2 Spark Plug Questions (2 pics)…. - JeepForum.com
post #1 of 7 Old 10-10-2013, 05:39 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
2 Spark Plug Questions (2 pics).....
Pulled my plugs to do a compression test and found this stripe down the side of the insulator on the #2 plug.
Anyone know what causes this?
Also, on the 258 using the standard Autolite 958 plugs, are the gaskets generally used?
And if so, which way do they go (large O.D. up/ down)?
Or does it matter?
2Xtreme is offline
post #2 of 7 Old 10-10-2013, 11:59 AM
superj
i would put those gaskets so the flat edge sits against your plug, like in the picture you put up.
as far as the stripe, thats crazy.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 7 Old 10-10-2013, 12:20 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
2X,
I think the staining just indicates how your plug was indexed in the cylinder. That's the combustion side and it's normal for it be a little darker. That one appears awfully dark (rich), though. Are the rest a similar color?
Here are mine after about 2500 miles on my rebuilt 360. As you can see, they are starting to get a similar burn pattern on the insulator tip, just not as dark as yours.
Matt
Matt1981CJ7 is online now
post #4 of 7 Old 10-10-2013, 12:24 PM
MoneypitCJ5
1977 CJ5
That almost looks like its arcing to the threaded base instead of the electrode. Weird...
I just did a tune-up on my Challenger and discovered NGK plugs tend to turn the ceramic red. So I guess weird stuff happens!
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #5 of 7 Old 10-10-2013, 12:47 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Matt1981CJ7 View Post
...That one appears awfully dark (rich), though. Are the rest a similar color?
They are.
Thing is there are ZERO miles on the plug.
I am trying to get a replacement engine running well enough to determine if it, or my original, she be the one rebuilt.
Thing seems to be running on 3 cylinders.
Has spark to all cylinders and good compression.
Pulled wires 4, 5 and 6 one at a time - neither made a difference. Pull any of the other 3 and it dies.
But that's a different thread.....
2Xtreme is offline
post #6 of 7 Old 10-10-2013, 12:56 PM
TheLaw360
1982 CJ7
I'm going to agree with arcing to the threads. spend 4 bucks and get a new one see if it does the same thing?
TheLaw360 is offline
post #7 of 7 Old 10-10-2013, 04:47 PM
86cj74.2L
86cj74.2L's Avatar
Once again Matt beautiful plugs.
One side will show color.
Back in 06 or something JH had a little blurb about why on the 258 the one side of the plug is clean and the other side shows color.
It looks too dark. But you won't know the truth till all cylinders are working and under load.
86cj74.2L is offline
