2 post fuel gauge - JeepForum.com
post #1 of 5 Old 03-21-2009, 04:43 PM Thread Starter
suddog
2 post fuel gauge
So I have been reading all the threads about temp and fuel gauges cause my temp gauge is always reading high. Come to find out the PO had a 2 post fuel gauge installed, instead of the 3 post fuel gauge. Has anyone had the similiar problem with aftermarket guages and is there a fix or mod? Thanks.
suddog is offline
post #2 of 5 Old 02-17-2010, 07:12 PM
pa30pilot
Did you ever find an answer? I am on this quest now.
pa30pilot is offline
post #3 of 5 Old 02-18-2010, 04:17 AM
John Strenk
John Strenk's Avatar
1976 CJ5
There have been many problems with the after market gauges. If you have the time I could help you try to fix them but if someone has a set they don't want, send them to me and I'll work out a step by step tuning.
First though you have to make sure the sending unit is operating properly. Then we might be able to fix the "New" gauges. It might be as simple as adding a resistor.
John Strenk is offline
post #4 of 5 Old 02-18-2010, 07:01 AM
pa30pilot
two post gauge
My problem is that the fuel gauge was probably working fine on the old set. It was my temp gauge that was blasted. Well, the new speedo does not even have an "I" post on the fuel gauge side so I have yet to figure out where to power the circuit so I don't inflict damage. At this point I think it may be resonable to scrap the "new" speedo and put my old one back in and try to track down oem fuel and temp combo. If I could just figure out where to power the thing, I can figure out the rest. Of course, it would have been nice if the seller instead of advertising an OEM replacement had pointed this little difference out. Plus the speedo is jerky compared to the old. Methinks this chinese stuff is crap.
post #5 of 5 Old 02-18-2010, 05:31 PM
BagusJeep
1981 CJ7
Chinese stuff suffers from "quality fade' so it may have been specced properly but later deliveries often are not of the same spec. Funnily in China they price low then cut the spec to make money but feel it is better to be asking forgiveness, if you notice, rather than seek permission.
As shipments are commonly paid for ex factory you have little recourse. there is a legal system in place but you may find the factory and the local court both report to the local communist party chief who could not give a rats ar$e about the silly foreigner. This is not to say you are being discriminated against, they do the same to each other.
This is a sweeping generalisation but I remember a conversation I once had with a Mr Bao in Beijing who was a JV partner on a bid. We were faced with an impossible schedule and he said "JUST LIE. LATER WE TELL THEM IT WILL TAKE LONGER"
I had my temp and fuel gauges replaced and they are fine. Unfortunately the fuel sender I now discover is from a Toyota and the readings are weak, a full tank showing 1/4 tank, probably a mismatch in output. I have discovered that empty means empty but that is all.
The idea about adding a resistor or even a rheostat to allow fine tuning is a good one. Unless you get good quality OEM parts you may find yourself still struggling with gauges. Fortunately the CJ-7 is a simple beast but it lends itself to inferior pattern parts being fitted.
Needless to say I will get an OEM sender from a reputable supplier in the USA and fit that rather than mess around with modifying a lash up.
BagusJeep is offline
Temp gauge and fuel gauge quit Foulplay Jeep CJ Forum 11 11-09-2012 09:43 AM
I Got My Fuel Gauge Working by Putting Stock Oil Gauge Back In Pog Jeep CJ Forum 4 11-09-2011 12:01 PM
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 05:49 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 12:41 PM
Fuel gauge, temp gauge HEADSPACEXXX Jeep CJ Forum 5 04-03-2008 05:26 AM
