2" lift-do I need extended sway bars? - JeepForum.com
post #1 of 5 Old 08-15-2009, 08:38 PM Thread Starter
Rocket6R
1981 CJ7
I've search the web and this forum for about 30 minutes and couldn't find an answers.
1981 CJ7 (258)
I'm thinking about putting on a 2" lift on my jeep and wondered if I need extended sway bars for the lift. Anyone have an opinion?
Thanks, Paul
Rocket6R is offline
post #2 of 5 Old 08-15-2009, 09:22 PM
CopperCJ7
I'm assuming you mean the vertical arms that connect the front sway bar to the leaf mounts. You might consider getting 2" longer (than OEM) quick disconnects for when you go off-road. With them disconnected, you'll get better articulation. Having said that, my 2-1/2" Rubicon Express lift came with quick disconnects that were 2-1/2" longer than my OEM arms.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #3 of 5 Old 08-15-2009, 10:26 PM Thread Starter
Rocket6R
1981 CJ7
Yah, I meant the vertical arms. Would the stock ones left on help prohibit the actual lift? Meaning, if I had 2" extended arms would I have a better lift height result form the 2" lift? I don't mean to be so crazy about this vertical arm issue, but I'm on a budget.
Thanks, Paul
Rocket6R is offline
post #4 of 5 Old 08-16-2009, 06:12 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
No you don't need them with such a small lift. Wait until you have the $ to upgrade them. Or search how to DIY extend them yourself, if you have the tools/skills.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #5 of 5 Old 08-16-2009, 11:42 AM
j33pman
I built my own extended arms/ disconnect last year, and I love them
Link goes to my website for the write-up
http://upstateoffroad.com/swaybar/swaybar.htm
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
Will I need extended brake lines for a 2.5" lift? SD84CJ7 Jeep CJ Forum 4 09-26-2009 08:01 PM
4" lift, do I need extended sway bar links? namredla Jeep CJ Forum 4 05-07-2009 06:20 AM
44" lift, extended brake lines? dragracer1199 Jeep CJ Forum 2 01-31-2008 01:33 AM
Extended brake lines, what stock hoses fit 4" lift StevenH Jeep CJ Forum 12 05-25-2007 11:48 PM
Cj7 Sway bars on a Cj5? CJ5_Fan Jeep CJ Forum 4 07-28-2004 10:13 AM
