2 inch body lift - JeepForum.com
post #1 of 5 Old 12-12-2002, 09:01 PM Thread Starter
crotz83
crotz83's Avatar
2 inch body lift
Hello everybody,
I have a couple questions....
I am looking for a 2 inch body lift for my 83 scrambler and i wanted to know if there is anyone out there that has one that they liked alot over another, or one to stay away from...pretty much which one should i buy that is most complete??
One more, i need to know everything that i will have to modify to make this all go together, hopefully in one afternoon. Everything as far as any part that will need lengthened, shortened, installed in some odd order...any tips of the install would be greatly appreciated, or just drop me a personal message if there in one of you out there with exactly what i'm lookin for and i'll work with you back and forth rather than via the forum page
Thanks alot ,
Justin
83 Scrambler, 33" mud terrains, NV4500, Centerforce Clutch, Dana 300, 350 ci, edelbrock 650 carb, 4" BDS springs, ss braid brake lines, currie greasable shackles, OBA-YORK-2.5gal tank, Hood lift
92 YJ, 35" Procomp Xtremes, SOA on stock springs, Heavy duty shackles, TJ long side shaft, JB Conversions SYE, JB4x4.com steering, 4.0l, ss braid brake lines
crotz83 is offline
post #2 of 5 Old 12-12-2002, 09:25 PM
jadams68
jadams68's Avatar
Daystar makes complete kits.
Some guys fab them out of aluminum, but I don't care for that.
I've done 3 Daystar kits on CJ-7s and I'd be more than happy to give you pointers.
email me : jadams68@bellatlantic.net
Here's your first tip: buy 2 cans of PB Blaster and saturate all of the body mounts and bolts....repeat twice a day until you run out...
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 12-17-2002, 08:45 AM
77mudder
performance
i did a performance 2 inch lift on my CJ7, replaced the body mount bushings at the same time. didn't have any problems until i tried to lower the radiator. I have installed a gear box out of an old wagoneer and since it is larger i was not able to lower the radiator. i don't run a shroud so i didn't have any problems really except for the top radiator hose. looks better in my opinon to not mess with the radiator. I think M.O.R.E. makes a good complete kit with poly bushings.
Did anybody have any problems with their steering components needing them lengthened?
stuff not together yet
almost done
77mudder is offline
post #4 of 5 Old 12-17-2002, 05:25 PM Thread Starter
crotz83
crotz83's Avatar
do new body mounts come in the kit as well?? i need to replace everything....the body mounts and i thought that a body lift would have everything included.....i want to replace all the cracked and squished rubber bushing thingys ....do these come in the kit???? any reply is very welcome,
Justin
crotz83 is offline
post #5 of 5 Old 12-17-2002, 07:25 PM
jadams68
jadams68's Avatar
Yes, the Daystar kits come complete with new bushings, bolts, washers and bushing sleeves.
jadams68 is offline
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 01:21 PM
1 inch body lift and mount for 75 CJ5 CJ5Doc Jeep CJ Forum 3 07-15-2009 06:56 PM
1 inch body lift jallen760 Jeep CJ Forum 5 10-25-2008 01:21 PM
4.5" Lift and 1 inch body 83 CJ5 Jeff5886 Jeep CJ Forum 3 10-03-2007 06:24 PM
Any tricks to do 3 inch body lift? XcessiveRebel Jeep CJ Forum 4 07-04-2004 11:18 PM
