2" Body lift problem - JeepForum.com
post #1 of 13 Old 11-10-2006, 09:04 PM Thread Starter
mustangdave357
Hello all, I just recently installed a body lift on my 78 CJ5 and now my steering shaft is too sghort. Is this shaft supposed to have room for adjustment where the litle shaft goes into the bigger shaft or does it just have adjustment at the steering box? Whats the easiest way to make this work with my setup? I am thinking I am going to have to cut it and weld a piece in? What have you done? Thanks, Dave
mustangdave357 is offline
post #2 of 13 Old 11-10-2006, 09:28 PM
John N
1981 CJ8
I replaced mine with a Borgesen, great product and took a lot of slop out of the steering. The stock shaft will extend, but it has 2 plastic pins in it and it may be rusted together. I took my stock shaft out, burned out the plastic pins with a propane torch and broke the rust free....then I gave to friend.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 13 Old 11-10-2006, 10:04 PM Thread Starter
mustangdave357
I am going to stick with the stock shaft for now, if I drill those plastic pins all the way through the shaft will slide where the small piece goes into the big piece? Once I extend it what do I need to do to reattach it because the plastic pins will be gone?
post #4 of 13 Old 11-10-2006, 10:29 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I think in my bl kit it came with 2 new roll pins,that where installed..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #5 of 13 Old 11-10-2006, 11:04 PM Thread Starter
mustangdave357
I just drilled out the 2 pins and it wont budge, I will have to heat it and try to free it up tomorrow, thanks!
post #6 of 13 Old 11-11-2006, 05:26 AM
Bard
I had to do the same for my 7, that is one project I didn't like for it took forever to finally get it to slide. I never replaced the plastic pins and never had an issue. Check your lower column bearing, perfect time to replace if needed.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #7 of 13 Old 11-11-2006, 03:49 PM
maine jeepster
i had a cj7 a few years back i drilled the pins and it still wouldn't budge so i jacked the body up to get the lift in it then 2 weeks later the steering column broke while i was driving down the road. now i replace all my steering shafts
maine jeepster is offline
post #8 of 13 Old 11-12-2006, 05:47 AM
jadams68
jadams68's Avatar
I melted the two plastic connectors as well. The outer shaft will fit over the inner.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #9 of 13 Old 11-12-2006, 06:41 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You guys are luckky, My PO cut the hole in the tub lower and mounted the end of the column lower on the firewall. It kinda makes for a perminant tilt wheel though.
John Strenk is offline
post #10 of 13 Old 11-12-2006, 11:13 AM
Indy
Indy's Avatar
Did you happen to keep the stock puck/rubber donut thingies? I need a replacement for between my grill and frame.
I'm the only gay eskimo.
Indy is offline
post #11 of 13 Old 11-12-2006, 12:55 PM
fatterman
fatterman's Avatar
I had to drill out those two pins, then I used a slide hammer and after about 30 minutes it finally broke free. Good Luck
fatterman is offline
post #12 of 13 Old 11-12-2006, 03:46 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've drilled the pins before and had the inner shaft rusted into the outer one. So I welded (more like a couple good tack welds) a small chunk of steel onto the inner shaft in such a way that it gave me a place to hit it with a hammer thereby driving it out of the outer shaft. After it came out, I ground the welds and knocked the chunk of metal off...
BESRK is offline
post #13 of 13 Old 11-13-2006, 08:06 AM Thread Starter
mustangdave357
I am going to fight with this shaft again tonight, I have been soaking it with PB Blaster for the past 3 days and tonight I am going to try to heat it with a torch, I didnt think of the slide hammer, thats a good idea and always worth a shot. At this point I am willing to try anything. I tried to push the 2 shaft pieces together just to break them free and that didnt even work. For a while there I thought they werent designed to come apart and I was going to have to weld a piece of pipe to the bigger shaft making it a little longer.
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
1980 cj5 1" body lift problem LSUtiger Jeep CJ Forum 9 12-19-2009 09:02 AM
Can anyone show me what a 4" lift and 1" body on a cj7 looks like with 35" tires yojeep79 Jeep CJ Forum 7 08-22-2009 04:56 PM
Will a 4" trailmaster lift and a 2" body allow for 35" baja claws. yojeep79 Jeep CJ Forum 13 08-19-2009 08:20 PM
Body lift problem ANJEEP69 Jeep CJ Forum 3 07-26-2005 09:39 AM
