2.5" suspension lift on 33x12.5" tires - JeepForum.com
post #1 of 14 Old 11-10-2005, 03:41 AM Thread Starter
cyjeeper
Hi there.
I'm currently restoring my Jeep and I'm about to change the whole suspension system.
I'm planning on using 33x12" tires. Do you think 2.5" lift will be enough to go with? I'm afraid that 4"/4.5" will be too much and less stable on the road. Can I use longer shackles to gain some more height?
I also need your opinion on which brand to go with. Doing my homework, I found out that Old Man Emu is the best, but doesn't produce suspension systems for CJ's. There's a "CJ Spring Conversion Kit for use with YJ Springs", but don't know if that's trustworthy. My 2nd best option is Rubicon Express. Any other better brand?
Let me know what you think.
Your help me is greatly appreciated!!
Thanks.
Xenios
cyjeeper is offline
post #2 of 14 Old 11-10-2005, 03:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Depends upon what you want to do and what axles.
On my Narrow track CJ5 I whent to 33X12.5 with 2-1/2" lift and 1" body lift and it seems to work nice with some rubbing on the inner fender.
But if you have a CJ7 wide track axles then you will rub on the outer lip of the fender and you will need more lift.
I have a BDS spring lift.
Without the lift:
With the lift.
John Strenk is offline
post #3 of 14 Old 11-10-2005, 04:27 AM Thread Starter
cyjeeper
Thanks my friend.
I'm just getting into Jeeps, so offroad, or lets say extreme offroad is not on my plans. Are you pleased with the BDS system you have? Do you think is better than RE and OME?
cyjeeper is offline
post #4 of 14 Old 11-10-2005, 04:35 AM
John Strenk
1976 CJ5
Well, it's stiff.
But I like it that way. Soft springs sagged to much with the plow on it.
I havn't tried any other.
post #5 of 14 Old 11-10-2005, 09:10 AM
jeepskate
I ran 32's on my '86 CJ-7 (you might want to include more info about your rig and intended usage, you'll get better answers) with a 2.5" Superlift and another 1/2" of lift from some Tomken shackles (most standard heavy duty replacement shackles are an inch longer than stock and will therefore give you a 1/2" of lift...I don't recommend much more than this in shackle lift) teamed with Rancho RS9000's for several years as a daily driver and moderate off-roader. For 33's, I'd add a 1" body lift. You'll also want to regear your axles to keep your performance up. Old Man Emu is arguably the best off the shelf lift for YJ's...adapting to a CJ is a fairly simple matter...there's nothing to trust or distrust about the conversion kit other than the price. The Rubicon Express Extreme Duty (*not* the standard duty) is probably the second best for YJ's and best for CJ's off the shelf and also offers a 4.5" version which Old Man Emu doesn't match. This is *also* a YJ kit...the CJ version just comes with the conversion parts. As far as the conversion, the rear is a direct bolt on. Up front you either use conversion shackle hangers and wider shackles or conversion shackles (this is the route RE uses...the top part of the shackle is the same size as stock to fit the stock shackle hanger, the bottom part is wider to fit the YJ springs). Beyond that, it's just new spring plates for the front with wider spaced holes.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #6 of 14 Old 03-14-2010, 09:47 PM
JacKedUP4x4
33x12.5 with a 2.5in suspension and maybe a 1in body
Would 33x12.5 tires fit on a TJ with a 2.5 in skyjacker suspension lift work? If not what if I got a 1in body? Not doing any more than a 1 on the body seeing how its pretty ugly and I don't want that huge gap
JacKedUP4x4 is offline
post #7 of 14 Old 03-14-2010, 10:01 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Whoa a 5 year old thread revived in the wrong forum. I can tell you that on my CJ I ran 33" tires on a 2.5" lift with no problems.. I got some rubbing on my leaf springs (which you wouldn't have to worry about!), but it could be corrected probably with less backspacing on my wheel.
If you'd like an answer by someone who is running a TJ, you should post in the TJ section here...
TJ Technical Forum - JeepForum.com
Welcome to the forum!
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #8 of 14 Old 03-15-2010, 06:39 AM
JacKedUP4x4
Hahaha no wonder why I only saw cj, sorry bout that and thanks for the help
post #9 of 14 Old 03-18-2015, 08:17 AM
RattlingCJ
1977 CJ5
Here's mine on 2-1/2" Rancho lift and 33's...
RattlingCJ is offline
post #10 of 14 Old 03-18-2015, 08:19 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Certainly the original poster from 10 years ago will chime in and let us know how the work went
Heck, the CJ has probably changed owners 3 times since then.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #11 of 14 Old 03-18-2015, 10:03 AM
orange150
1982 CJ8
Originally Posted by Ken4444 View Post
10 years ago
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #12 of 14 Old 03-20-2015, 09:35 AM
RattlingCJ
1977 CJ5
The age of the thread does not keep us newbz from having the same questions.. lol
post #13 of 14 Old 03-20-2015, 11:30 AM
CSP
It doesn't prevent newbs from starting their own thread in the correct forum for the model of Jeep they have either.
CSP is offline
post #14 of 14 Old 03-23-2015, 07:28 AM
RattlingCJ
1977 CJ5
As long as his question got answered. I'm cool with the occasional thread violation without castration.
Can anyone show me what a 4" lift and 1" body on a cj7 looks like with 35" tires yojeep79 Jeep CJ Forum 7 08-22-2009 04:56 PM
33x12.5 tires... 8" or 10" wheel width? jetskibob1 Jeep CJ Forum 6 02-18-2009 03:08 PM
Pictures of 33x12.50's on CJ7 w/ 2" Body Lift?? volfan Jeep CJ Forum 7 06-09-2008 10:39 AM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 10:40 PM
4" Lift with 1" body and 35" tires?????? RobP Jeep CJ Forum 14 08-24-2006 06:59 AM
