2.5 or 4" lift kit? - JeepForum.com
post #1 of 16 Old 11-24-2012, 01:24 AM Thread Starter
ironbyron1
1977 CJ5
2.5 or 4" lift kit?
I keep going back and forth on this. I like the idea of being able to go up to 33" tires with the 4" lift. But I wonder about stability issues. I plan to add wheel spacers if I do the 4".
Anyhow, you tell me, 2.5 or 4"?
Thanks!
Byron Oost
Owensboro, Kentucky
ironbyron1 is offline
post #2 of 16 Old 11-24-2012, 06:21 AM
keith460
Jeep. There's Only One
keith460's Avatar
Put it this way, I had a 4"- 4.5" lift kit and 33" tires and between a stiff harsh ride and slight driveshaft vibrati0ons, it wasn't worth it. Now we installed a 3" spring lift with 32" tires and it is not harsh ride and no vibrations at all. A 3" lift will still clear 33" tires and so will a 2.5" lift kit. But if you plan on doing some hardcore offroading, then perhaps a 1" body lift would be needed with a 2.5" spring lift.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 16 Old 11-24-2012, 06:39 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I agree with Keith. Anything over 3" results in steering, drivetrain and ride quality issues that will need to be addressed.
When I weighed the extra work, and $$, all for a 1" larger tire (32" vs. 33"), it wasn't worth it to me. I stuck with a 2.5" lift and 32"x 11.5" tires, stock steering and drivetrain.
Matt
Matt1981CJ7 is online now
post #4 of 16 Old 11-24-2012, 06:40 AM
wvrefugee
1979 CJ7
2" at best! This is also a great/cheaper way to upgrade your suspension without buying leafs seperately. I recently used a 2.5" BDS system and love it!
wvrefugee is offline
post #5 of 16 Old 11-24-2012, 07:04 AM
gojeepin
1983 CJ7
Matt
Any issue you see above can be addressed. I have a 4.5" suspension and 1" body lift to run 35s. I fixed all the problems myself.
In addition, just staying below 4" lift may not avoid those problems. It depends on the design of the lift.
The question is, do you want to and will you do most of the work yourself? If you don't want to deal with those issues, go with a 2.5" lift.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #6 of 16 Old 11-24-2012, 04:34 PM
wvrefugee
1979 CJ7
AND, a 2.5" lift makes an easier ride from Moonlite BBQ!!
post #7 of 16 Old 11-24-2012, 04:34 PM Thread Starter
ironbyron1
1977 CJ5
What problems did you have to fix, if you don't mind letting me know?
Thanks,
Byron Oost
Owensboro, Kentucky
post #8 of 16 Old 11-24-2012, 04:37 PM Thread Starter
ironbyron1
1977 CJ5
Down Parrish Avenue?
Where the meat's good and lean?
You'll see what I mean,
The made Owensboro, the BBQ Capitol of the world!
LOL!
Byron Oost
Owensboro, Kentucky
post #9 of 16 Old 11-24-2012, 06:27 PM
CJ8Hokie
1983 CJ8
I have a 4" lift (Pro Comp *$@#!!!!) and wish I had a 2.5" lift. From the looks of things I could still easily fit my 33" AT's as it's mainly a pavement pounder.
1983 Jeep CJ-8 - Clifford Performance 258/4.0 with MPFI
CJ8Hokie is offline
post #10 of 16 Old 11-24-2012, 07:30 PM
b-dog
i would like to put a 2.5" ome on my cj7 and run some 33" a/t tires with 10" wheels. lot of people say that they will rub. some say they want. i don't do any off roading with mine either.
b-dog is offline
post #11 of 16 Old 11-24-2012, 09:32 PM
wvrefugee
1979 CJ7
Bbq
LOL!
Been there many times my friend! Lived in Loserville for 18 years!
post #12 of 16 Old 11-24-2012, 09:32 PM
wvrefugee
1979 CJ7
Spacers
1.5" spacers have been fine for me.
post #13 of 16 Old 11-25-2012, 06:01 AM
Matt1981CJ7
1981 CJ7
b-dog,
Here's my 2.5" OME lift with a new 32"x11.50" tire fully tucked. Stock hangers and body mounts.
I'm afraid 33"'s would rub, without some additional lift.
Hope this helps,
Matt
post #14 of 16 Old 11-25-2012, 07:00 AM
gojeepin
1983 CJ7
Thanks,
1) Driveline angle. I fixed it with remounting the perches and using a Double Cardin driveshaft.
2) Caster Angle. I fixed it by measuring, marking, and grinding the new angle into the base of the perches. Dana 30 perches are thick and can be reshaped within reason.
gojeepin is offline
post #15 of 16 Old 11-25-2012, 09:23 AM
Alex77cj7
1977 CJ7
I have a 4" with 33" tires and I love it! I'm about to change to 35's though.. I was running 33's stock with a little rubbing so i know you could run them with no problem on a 2.5"
Alex77cj7 is offline
