2/3 carb better than none - JeepForum.com
post #1 of 23 Old 07-08-2012, 01:01 PM Thread Starter
John Strenk
John Strenk's Avatar
1976 CJ5
Amazing untouched video showing engine operating with only 2/3 of the carb installed
No metering needles
No choke
No accelerator pump installed
Yet this amazing carburetor operates the engine even rervving it up to 2500 RPM.
Paranormal activity? Alien power source? Teenage mutant ninja squirrels?
Nope just plain old American engineering!
John Strenk is online now
post #2 of 23 Old 07-08-2012, 01:05 PM Thread Starter
John Strenk
1976 CJ5
post #3 of 23 Old 07-08-2012, 01:19 PM
VACJ7
Hockey Rules!
VACJ7's Avatar
OK, so most of us that have had a BBD could barely get it to run fully assembled. What gives John???
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline
post #4 of 23 Old 07-08-2012, 01:27 PM Thread Starter
John Strenk
1976 CJ5
LOL
All I did was buy a $20.00 rebuild kit, some NAPA carb cleaner (1gallon dip can) and some wire.
This carb still has a worn throttle shaft hole. You can hear the whistle as I rotate the throttle.
That and running bare 3 times CCW around the jeep waving a D300 shifter and a necklace of empty Coor bottles around my neck during a full moon. Chanting " CJ, CJ, CJ, ..."
post #5 of 23 Old 07-08-2012, 07:02 PM
86cj74.2L
86cj74.2L's Avatar
Is that the one your sending me? I'll try not to take the magic out of it if so......
86cj74.2L is offline
post #6 of 23 Old 07-08-2012, 07:21 PM
swatson454
1983 CJ7
That must be where I screwed up on mine. I did the ol' reading entrails and rattling chicken bones routine and I came up short.
Now I can't stop picturing you in a loin cloth with a clinking Coors necklace. Oooga shaka, oooga shaka CJ CJ oooga shaka
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #7 of 23 Old 07-08-2012, 08:16 PM Thread Starter
John Strenk
1976 CJ5
Ye,the same one.
Just use gloves and you'll be OK
post #8 of 23 Old 07-08-2012, 08:19 PM Thread Starter
John Strenk
1976 CJ5
Oh, yeah. Those are just for fortune telling and we all know there is no fortune in Owning a CJ.
Chicken bones should of helped though. Did you CW or CCW?
post #9 of 23 Old 07-08-2012, 08:46 PM
LumpyGrits
Done that many a time with my BBD to set the float.
Just make sure you remove the coil spring from the plunger area.
LG
LumpyGrits is offline
post #10 of 23 Old 07-09-2012, 02:30 AM Thread Starter
John Strenk
1976 CJ5
LG
Certainly would be a accurate way to set the floats.
A lot of trouble to go through though.
Why do you have to remove the spring though? there should be nothing but vacuum there but I guess a little backfire could send the spring to never never land.
Here's a question though, would the level be higher or lower with 10% ethanol in the fuel? I'm just wondering if the floats would float higher or lower in the liquid?
post #11 of 23 Old 07-09-2012, 03:20 AM
86cj74.2L
86cj74.2L's Avatar
What's the specific gravity of ethanol? That may tell.
post #12 of 23 Old 07-09-2012, 06:53 AM
jdboy
I just wish my carburetor looked that good! Mine is a leaky ugly mess but consistently knocks down 19-20mpg. With all the horror stories around here about these carb's I'm afraid to take it apart to clean it and install new gaskets.
jdboy is offline
post #13 of 23 Old 07-09-2012, 07:20 AM Thread Starter
John Strenk
1976 CJ5
post #14 of 23 Old 07-09-2012, 09:07 AM
LumpyGrits
John
No trouble at all, you have to take the "lid" off the carb. to set the float to begin with.
No real word diff. in level with "E" in it that I have seen.
The shak'n of the engine on start-up has thrown the spring out of the carb.
LG
post #15 of 23 Old 07-09-2012, 09:15 AM Thread Starter
John Strenk
1976 CJ5
Ahh, I warmed my engine up before I started it and started real smooth.
I'm use to setting my floats with the whole carb off the engine and inverting the carb to set the floats.
This would be easier though as long as you don't loose any of those Jesus clips.
