1996 4.0 Head worth swapping onto 258? - JeepForum.com
post #1 of 10 Old 01-01-2010, 06:18 PM Thread Starter
deezil
I recently got a nice 4.0 1996 head off of a low mile Cherokee.
I want to do the head swap on my 1985 AMC 258 But since this is the later head is it worth doing or should I just look for a earlier head?
Thanks ahead of time.
deezil is offline
post #2 of 10 Old 01-01-2010, 06:29 PM
fredrok
casting numbers you want to look for:
1991-95......7120
1996-99......0630
The '91-'95 HO heads with casting no.7120 have the highest intake and exhaust port airflows, especially at lower valve lifts where it is most important, and are the best for performance. The '96-'99 0630 heads are almost identical except that they don't have a port for the coolant temp. gauge sending unit.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #3 of 10 Old 01-01-2010, 06:37 PM Thread Starter
deezil
I Think mine is the 0630 head. It's getting hot tanked now, so I will check for sure when I get it back.
deezil is offline
post #4 of 10 Old 01-01-2010, 11:23 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
1991-95......7120
1996-99......0630
It should be noted that the comment about the 7120's flow rates matter more if you aren't planning on any flowbench work. Once you start working 4.0 heads, getting any particular casting number for the purpose of cfm is less important, as the other castings get "brought up to speed" by the mods.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #5 of 10 Old 01-02-2010, 12:00 AM Thread Starter
deezil
I Just plan on just polishing it up a bit and calling it done. It came off of a late 1996 Cherokee I think its safe to say its a 0630 and so far from what I read while searching the net it isn't all that bad of a head.
Lets hope it's a good core when the shop takes it apart.
deezil is offline
post #6 of 10 Old 01-02-2010, 08:45 AM
fredrok
Blend the radii where it transitions from the port to the bowl area, then clean up the area of the bowl where it meets the seat AFTER the 3 angle valve job is performed (see pic below). Clean up and smooth any areas in the combustion chamber that are sharp-your goal is to smooth them and remove as little material as possible in the chamber-(see pic), both of which will require you to be very careful not to nick the seat area. You can also use the gasket to set your profile and raise the roof area of the exhaust port if it requires it (assuming your exhaust manifold or header matches the exhaust gasket) and then LEAVE THE REST ALONE.
Unless you're going with MPFI, do not bother to polish anything. You'll waste your time and likely make atomization worse. (when the design is already bad anyway)
Without a flow bench and experience, you'll get much better results from these small improvements than you would going hog wild porting and polishing. Good luck and have fun.
This was taken after a quick job I did many moons ago on a 258 head before I converted to a 4.0. Same rules apply.
fredrok is offline
post #7 of 10 Old 01-02-2010, 12:46 PM
wendell
1987 YJ Wrangler
To get the most benifit from the 4.0 head swap, also intall comp cam exteme energy 4X4 cam # X4250H. This will also allow you to run a holley 470 TA 4 barrel and offy intake. It will take the fuel of a 470 instaed of having to run the 390. The holley TA series 4 barrels are made for off road and can handle some extreme angles. The 4.0 head a long with the cam is good for about 40 extra hp. The head a lone won't get you there like alot of people say.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #8 of 10 Old 01-03-2010, 11:27 AM
Boodie
1961 CJ5
I LOVE my 4.0 HO Head conversion! Better mpg, better compression, more HP. If you're not building a hot rod/drag racer then it's the way to go!
1961 Willys CJ-5
258 I6/4 Inch Suspension Lift/3 Inch Body Lift/2 Inch Shackle Lift/34" Tires
Boodie is offline
post #9 of 10 Old 01-03-2010, 12:34 PM
CJFF29
1979 CJ7
I was looking at one point to do a 350 swap but after reading other posts it seems like lot more work than I am ready for. I have a 79 with a donor 258 in it. I also have the original motor. I read somewhere only certain year blocks can be used for this swap. For that matter it seems like lot of upgrades and parts only apply to '81 and newer why is that aren't all 4.2 258's made the same?
CJFF29 is offline
post #10 of 10 Old 01-03-2010, 01:12 PM Thread Starter
deezil
I know of someone that has used a 4.0 head on a 1972 258........ I assume it will pretty much work on any 258
deezil is offline
Swapping a T-150 into a T-5 zenki4u01 Jeep CJ Forum 2 01-15-2010 02:07 PM
4.0 head vs 4.2 head with angled valves DL_81_CJ7 Jeep CJ Forum 1 08-02-2009 08:15 PM
Is it worth it to put a 4.0 head on a carb'd motor? CAS CJ7 Jeep CJ Forum 6 08-16-2007 03:59 PM
High Output Head on 258 I6 Worth it?? qwert98 Jeep CJ Forum 7 05-07-2007 05:35 PM
Round Head Light Square Head LIghts? Daniel W Jeep CJ Forum 5 07-27-2003 08:25 PM
