1986 CJ7 Metal dash replacement level of difficulty? - JeepForum.com
post #1 of 4 Old 03-06-2011, 09:26 PM Thread Starter
KansasKate
I'm looking for an über-original 1986 CJ7. Most of the ones I've found have a butchered dashboard. In most cases, the 2-knob radios have been replaced with DIN mount stereos. I know this may sound silly to some (or everyone), but the painted metal dash is one of the main reasons I'm looking for a CJ. I'm not interested in anything to cover the holes; I don't want to turn the DIN mount area into a cubby hole. I just want it to look like it did when it was built in 1986.
So, my question is this: if I find an otherwise good '86 CJ7, how hard is it going to be to replace the metal dash? Is that something that bolts on or would it have to welded or what?
MTIA!
KansasKate is offline
post #2 of 4 Old 03-06-2011, 09:44 PM
supersport126
Its bolted on and easy swap...if you dont freak out unplugging EVERYTHING electrical, lol. everything on the dash must be disconnected and then swapped into the new one...and then reconnected!
supersport126 is offline
post #3 of 4 Old 03-06-2011, 09:59 PM
VACJ7
VACJ7's Avatar
It's pretty easy. Much easier to unbolt the dash and slide it out some then disconnect all the wires one by one and labelling as you go from above. Otherwise you are contorted in s asmall cramped space doing it from below. I put a couple of long bolts in to rest the dash on as I slide it out. 1/4-20. Then pull the dash with all the gauges attached.
VACJ7 is offline
post #4 of 4 Old 03-07-2011, 04:52 AM
243
1978 FSJ Cherokee
If the rest of the Jeep is in good shape, I would not let a butchered dash stop me from buying it. You can get original dashes off Ebay and Craiglist and a reproduction in stainless for less than 200.00. And, the stainless can be painted to match the Jeep.
Dave's 78 Build
243 is offline
cj7 , dash board problem , dashboard , interior paint , stereo
1986 CJ7 Heater Core Replacement dhood Jeep CJ Forum 21 04-06-2013 08:16 AM
who has done inner oil seals on a dana 30? level of difficulty? wizim Jeep CJ Forum 11 11-19-2009 02:54 PM
Taking off the dash - CJ7 1986 GrantPantling Jeep CJ Forum 8 02-12-2009 02:58 AM
Help on Engine Replacement for 1986 CJ7 smitty.pd Jeep CJ Forum 0 05-08-2006 11:47 AM
metal dash? DIXIE Jeep CJ Forum 2 11-12-2002 02:37 PM
