1986 CJ7 Horn problems - Page 2 - JeepForum.com
post #16 of 18 Old 06-07-2011, 07:31 PM
MoC
I got tricked by txrj's recent post when he said he came across the post and it helped him fix his.
BTW welcome to the forums txrj!!
MoC is offline
post #17 of 18 Old 06-12-2011, 03:49 PM
Blue83CJ7
1980 CJ7
Since I JUST dealt with this today, I thought I would continue to build this old thread :-)
My battery died in the parking lot of a Les Schwab while I was checking out some 33's (I ended up not buying yet) but I Figured since my jeep came with a battery that looked fit for a lawn tractor, I sucked it up and bought a real truck battery for $55.
I just got back from a 1 week vacation and my battery was totally dead.
As I started looking for what could be draining my battery that wasn't before, I remembered that the Horn relay stopped "clicking" when I pushed it (my horn doesn't work so no big deal, will fix it later)
Remembering this, I removed the steering wheel cap and debated whether I should pull it all apart I noticed a small metal shaving shorting out the horn ring to the wheel nut.
I brushed it away with my fingertip, and relay now clicks again, problem solved.
Easiest/cheapest repair ever!
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #18 of 18 Old 06-13-2011, 07:57 PM Thread Starter
elboe805
Original poster here.... Thanks for all the insight gentlemen. Jumped a lead wire from the battery to the positive on the horn and it fired. The relay would click intermittently once depressed. Not exactly sure what the remedy was, but here's what I did-
cleaned the terminals of the horn
replaced the relay (4$)
and sand blasted the 1/8" of rust off of the metal plate that completes the circuit inside the horn.
15 minutes later, my la cucaracha horn is back! (just kidding)
elboe805 is offline
1986 CJ-7- 258 with 2150 Motorcraft Carb idle problems ET48 Jeep CJ Forum 10 04-09-2010 10:33 AM
Horn problems... Dborns Jeep CJ Forum 6 03-02-2010 01:18 PM
Need help replacing horn with a 2 horn air horn!! xbarksdale Jeep CJ Forum 10 03-15-2009 02:56 PM
Horn Relay On 1986 CJ7 dhood Jeep CJ Forum 10 04-24-2008 08:22 PM
Replace air horn or get electric horn? explortainment Jeep CJ Forum 1 05-02-2003 04:27 PM
