1986 CJ7 Horn problems - JeepForum.com
post #1 of 18 Old 03-10-2011, 08:08 PM Thread Starter
elboe805
Hello All;
First off, I'm new to the Jeep world and I want to thank everyone for the knowledge that they freely share with a noob like me... You guys Rock!
My question- My horn quit working today... I can't seem to find a diagram for the fuse panel (I'm gonna sack up and buy the Haynes manual this weekend.) So;
1) Is there a fuse in the panel for the horn?
2) If so, where is it?
3) Or is there just the horn relay?
I'm not hearing any "clicking" sounds when I depress the horn in the cab so I'm wondering (if there is one) if it's a bad fuse. Any ideas?
elboe805 is offline
post #2 of 18 Old 03-10-2011, 09:05 PM
lanecj5
1980 CJ5
The horn relay is at your left knee if sitting in the drivers seat.Reach up under the dash...Square relay 1"x1".If its not clicking then your right..check the fuses.Replace every blown fuse in the box.Press the horn..did any fuses blow?If yes it could be a short in the relay;replace the fuse...unplug the relay.Get your volt meter or light, test the power in side of the wire connector by pressing the horn,Do you have power?Did another fuse blow?also bypass the horn button and relay by running a jumper wire over to your battery from the positive side of the horn to the pos. post on the battery..Did it blow?If it did the horn is good.Go back to the relay its just a few dollars;replace it.If it continues to blow fuses it could be a shorted wire..trace the wire from the horn(red/white).
lanecj5 is offline
post #3 of 18 Old 03-10-2011, 09:08 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This post has links to the 84 to 86 factory service manual which has schematics:
http://www.jeepforum.com/forum/f8/84...27/index2.html
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #4 of 18 Old 03-11-2011, 06:08 AM Thread Starter
elboe805
Thanks for the info guys... LOL- This is already getting addicting and I've only had the Jeep 3 days!
elboe805 is offline
post #5 of 18 Old 03-11-2011, 07:46 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Glad to help! And, welcome to Jeepforum! You'll find a lot of helpful folks here. If you're spending any time behind the dash panel troubleshooting electrical stuff, and you decide that your gauges aren't working right, this apge is very helpful:
http://home.roadrunner.com/~john.str...for_cj_gau.htm
Ken4444 is offline
post #6 of 18 Old 03-11-2011, 08:39 AM
DT5150
1983 CJ7
you can hook up the horn itself directly to a 12v battery and see if it works. no blow, buy a new horn. easier than checking fuses and relays, and could save you some time and trouble. i always try the easiest things first.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #7 of 18 Old 03-11-2011, 11:58 AM
Erik719
1983 CJ7
Had the same problem on my'83. Turned out to be the horn button in the steering wheel, but I found that out by following the trouble shooting mentioned above.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #8 of 18 Old 06-07-2011, 04:36 PM
txrj
1985 XJ Cherokee
Thanks guys! I just came across this post when my horn stopped working on my 85 Jeep Cherokee, and apparently I have that same little white little square relay under my dash and it had come a little loose. Once I pushed it in all the way, my horn was working again and I was able to pass vehicle inspection!
txrj is offline
post #9 of 18 Old 06-07-2011, 05:08 PM
MoC
Also check the ground. If you hear a clicking the relay should be working. The horn grounds off to the fender it is attached to through the screew that holds it in place.
MoC is offline
post #10 of 18 Old 06-07-2011, 05:10 PM
wellmax
the problem with the horn on my 84 cj was in the steering wheel horn button.
got it fixed, but that was a horse of a different color, hope your problem is the relay or horn itself.
wellmax is offline
post #11 of 18 Old 06-07-2011, 06:41 PM
BagusJeep
1981 CJ7
If you prise off the steering wheel boss you will see the electrical switch is real simple, a circle of copper. If you have a meter you can test the innards in a few seconds or just try pressing it in. If it operates correctly you need to bend the copper out a bit so the button hits it.
BagusJeep is offline
post #12 of 18 Old 06-07-2011, 06:46 PM
MoC
Likely not the horn button since the OP said he heard a clicking when he pushed the horn. The clicking is likely the horn relay which means the horn button itself is working.
MoC is offline
post #13 of 18 Old 06-07-2011, 07:15 PM
Coiz
1979 CJ7
You do realize the OP was three months ago. He never came back to tell us what fixed it.
Mike
Coiz is offline
post #14 of 18 Old 06-07-2011, 07:19 PM
MoC
Nooooooooooooooooooooooooooooooooooooooooooooooooo o!! Say it a so!! Woops!
MoC is offline
post #15 of 18 Old 06-07-2011, 07:20 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
JF forum regulars, used and then thrown out like a greasy paper plate...
heh
Ken4444 is offline
1986 CJ-7- 258 with 2150 Motorcraft Carb idle problems ET48 Jeep CJ Forum 10 04-09-2010 10:33 AM
Horn problems... Dborns Jeep CJ Forum 6 03-02-2010 01:18 PM
Need help replacing horn with a 2 horn air horn!! xbarksdale Jeep CJ Forum 10 03-15-2009 02:56 PM
Horn Relay On 1986 CJ7 dhood Jeep CJ Forum 10 04-24-2008 08:22 PM
Replace air horn or get electric horn? explortainment Jeep CJ Forum 1 05-02-2003 04:27 PM
