1986 CJ7 Heater Core Replacement - Page 2 - JeepForum.com
post #16 of 22 Old 03-09-2012, 03:09 PM
DoubleDown
1983 CJ7
Who sells the best replacement heater core ? Or should I have mine flushed if it's not leaking. Are there any better heater cores out there ? I will be doing the blower motor upgrade and wanted to know what my options are once I'm in there. Thanx.
DoubleDown is offline
post #17 of 22 Old 03-14-2012, 11:43 AM
DoubleDown
1983 CJ7
RockAuto.com has a few heater cores listed. One is VISTA-PRO Part # 399210, Core Size 7 7/8 x 6 1/8 x 2. Does anyone know what the stock core size is for my '83 4.2L ? Basically asking if this one is bigger or smaller and if its bigger can I modify the box to make it work ?
post #18 of 22 Old 03-14-2012, 04:33 PM
Mike Romain
It has to be the right size and is easy to get usually. If it is not leaking, then a good flush usually does it wonders. They don't go too often, but I did replace mine while it was open if I remember right.
Mike
Mike Romain is offline
post #19 of 22 Old 02-18-2013, 07:15 PM
Chieftaz
I've got to change my heater core this week. Of course it waits until its 12 degrees out to start leaking! My question is, can you replace the studs that come through the firewall if you were to snap one? And where can you get them if you can replace them?
Chieftaz is offline
post #20 of 22 Old 04-04-2013, 11:41 AM
Chieftaz
Luckily I got the heater box off without snapping the studs... Moral of the story is dont let someone else bed line your firewall unless you tell them what not to cover!
Chieftaz is offline
post #21 of 22 Old 04-04-2013, 01:03 PM
DoubleDown
1983 CJ7
I might run into the same problem. Also, quadratec has a core for $63, autozone $38 didn't check napa yet but what's the difference ?
post #22 of 22 Old 04-06-2013, 09:16 AM
DoubleDown
1983 CJ7
Still trying to decide which core to get. The prices vary a lot and have no reviews to go on. I was hoping to get some input from here. Is there anything I should stay away from or are they all the same ?
Need HELP with Heater Core!! Minisink1 Jeep CJ Forum 10 11-11-2008 06:24 PM
heater core madadsnt Jeep CJ Forum 5 04-09-2007 05:01 PM
Heater Core replacement fyr196 Jeep CJ Forum 7 10-29-2006 05:30 PM
78 CJ7 Heater Core replacement craigsattic Jeep CJ Forum 7 10-27-2006 07:02 AM
Help on Engine Replacement for 1986 CJ7 smitty.pd Jeep CJ Forum 0 05-08-2006 12:47 PM
