1986 CJ7 Heater Core Replacement - JeepForum.com
post #1 of 22 Old 04-02-2008, 07:33 AM Thread Starter
dhood
Hey Guys,
I am replacing my heater core this weekend in my 86 CJ7 4.2 and was wondering if I should anticipate any surprises? It looks pretty cut and dry but you never know. You know any hidden nuts, screws, clips, or look out when you do this becasue this will happen, stuff like that. Any tips or tricks would be appreciated. Thanks
Dave
dhood is offline
post #2 of 22 Old 04-02-2008, 08:02 AM
hdroadkingc
Cut and dry except the nut behind the valve cover can be a pain.
hdroadkingc is offline
post #3 of 22 Old 04-02-2008, 08:48 AM Thread Starter
dhood
Didn't know about the nut behind the valve cover. That's what I'm talking about. I appreciate the help.
Dave
dhood is offline
post #4 of 22 Old 04-02-2008, 12:23 PM
Mike Romain
While you are in there, I recommend an upgrade to a big GM heater blower. They fit right into the heater box and squirrel cage and out out more on low than the stock one does on high. You have to cut the hole in the firewall a little bigger.
It's soo nice to have 'all' my windows defrost at -20 or colde, let alone not needing gloves or a ski suit...
Here is one link on doing it: http://jeep.off-road.com/jeep/articl....jsp?id=261421
Mike
Mike Romain is offline
post #5 of 22 Old 04-02-2008, 12:44 PM Thread Starter
dhood
thanks I was already considering that while I was researching the heater core.
dhood is offline
post #6 of 22 Old 04-03-2008, 08:26 AM
heath84CJ7
heath84CJ7's Avatar
Make sure you get the heater blower motor for a Blazer that is a short shaft. I got one from Napa that was to long. Went back and got the other and it was fine. I believe the Napa Part number was 655-1039 if memory seves me correct.
heath84CJ7 is offline
post #7 of 22 Old 04-03-2008, 08:56 AM
Mike Romain
The last ones I bought were the cheaper one of the two. The 'premium' one had the longer shaft. I am up in Canada though.
Mike
post #8 of 22 Old 12-12-2011, 11:03 PM
brad607e13
Just replaced heater core in 84 CJ7 4.2L Not to bad a job. 4 nuts to remove from engine compartment side of firewall, 1 behind valve cover, 1 right and below battery, 1 under battery close to drain tube, 1 left and below battery. Unplug electrical wire close to drain tube. Inside the cab, unhook 2 cable controls in the center area along with defrost duct directly above them. Entire system will come off of firewall. Remove back plate and replace core. Reverse steps to reinstall. Hope this helps.
brad607e13 is offline
post #9 of 22 Old 12-13-2011, 05:20 AM
KJNewbs
1983 CJ7
On the long shaft vs short shaft side of things, what happens/doesn't work with the long shaft?
I did this a couple of weeks ago, and when I was done I noticed that the cylinder that attaches to the motor (to move the air) rubbed on the front plastic part of my enclosure after I put it all together.
That didn't seem to be because of the shaft, but more because of the added bump out at the shaft base, but am I wrong?
Long story short, I'm wondering if my problem is caused by having the "long shaft" one.
As far as the OP, the directions offered above are pretty spot on. While apart, check all of your foam seals and what not. When I did mine, I replaced all of it to achieve tighter seals around the flaps and what not.
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #10 of 22 Old 12-13-2011, 07:47 AM
CJ Chet
If you go to Autozone, they've already done the work for you. Just tell them you want a blower motor for an '86 CJ7 and you'll get the proper upgrade motor (pm102).
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #11 of 22 Old 12-13-2011, 08:33 AM
Renegade82
1982 CJ7
Do all the upgrades require cutting a larger motor hole?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #12 of 22 Old 12-13-2011, 11:16 AM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, if you want to use the tried and true Chevy Blazer motor. The larger motor gives you more rpm then the inadequate OEM fan motor ever would. Low setting on the Blazer type motor is close to the High setting on the OEM fan motor.
1984 CJ-7 Renegade
keith460 is online now
post #13 of 22 Old 12-13-2011, 01:00 PM
DoubleDown
1983 CJ7
Someone on this forum posted a very pic heavy heater box rebuild, but I can't find it in the searches. Could someone post a link ?
Thanks. I need to do mine as well.
DoubleDown is offline
post #14 of 22 Old 12-13-2011, 01:02 PM
Capt_Drake
http://www.jeepforum.com/forum/f8/cj...-heavy-975999/
Capt_Drake is offline
post #15 of 22 Old 12-13-2011, 01:46 PM
DoubleDown
1983 CJ7
Thanx. Very Helpful.
Need HELP with Heater Core!! Minisink1 Jeep CJ Forum 10 11-11-2008 05:24 PM
heater core madadsnt Jeep CJ Forum 5 04-09-2007 04:01 PM
Heater Core replacement fyr196 Jeep CJ Forum 7 10-29-2006 04:30 PM
78 CJ7 Heater Core replacement craigsattic Jeep CJ Forum 7 10-27-2006 06:02 AM
Help on Engine Replacement for 1986 CJ7 smitty.pd Jeep CJ Forum 0 05-08-2006 11:47 AM
