1986 CJ7 Gauges PROBLEM!!!! - JeepForum.com
post #1 of 5 Old 10-04-2011, 08:24 PM Thread Starter
Martinez53
1979 CJ7
Hello
its been a while since i have been on. Here is the problem.
Problem:
Ammeter gauge, Temperature gauge, and oil pressure gauge, Fuel aren't working. they were working a few days ago.
Hypothesis:
Bad fuse or bad ground. But wait, if its a bad ground, the lights for the speedometer shouldn't work correct? What fuse supplies power to the gauges? Pictures of the fuse diagram would be helpful. ALso if one has a key for the fuse block, can you please post it.
Solution:
n/a
Thanks again for your time and input!
Thanks
Lance
Martinez53 is offline
post #2 of 5 Old 10-04-2011, 08:52 PM
BagusJeep
1981 CJ7
This is the 1984-86 fuse block layout. Looks like the 15 Amp fuse to the computer and "instrument cluster" i.e. gauges. (LPS). I do not have a pictre of the real life fuse box but you get the drift.
If your engine is working have you got the computer? If so how is it being powered?
It may not be the fuse of course.
Enjoy frustration? Then look at the electrics.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 5 Old 10-05-2011, 02:39 AM
John Strenk
John Strenk's Avatar
1976 CJ5
79 was almost the same as the 84 fuse box posted above.
Some of the fuses sizes are different to support the computer load.
This is an 82 fuse box but should be the same.
Get your test light out and start checking. IGN LPS
John Strenk is offline
post #4 of 5 Old 10-05-2011, 06:08 AM
slo100
What kind of connector is that in the radio. In my new-to-me 84 CJ7, the PO has rigged an awful tap for the radio and the factory radio slot is empty. It would be nice to wire it like this one.
I also have the gauge outage in mine so thanks for posting. Any other advice would be helpful.
Many thanks!
slo100 is offline
post #5 of 5 Old 10-05-2011, 09:05 AM
John Strenk
1976 CJ5
That radio plug is just a spade connector in a housing.
4.2 , cj7 , electrical , gauges
1986 CJs batcave4 Jeep CJ Forum 4 08-31-2011 05:35 PM
Mechanical gauges DEFINETELY better than the stock electical gauges jeepguy85 Jeep CJ Forum 33 01-14-2010 08:20 PM
Can you help me price my 1986 CJ-7? smithgrow Jeep CJ Forum 4 03-18-2008 11:07 AM
1986 cj 7 Smalls Jeep CJ Forum 5 04-08-2003 08:09 AM
1986 CJ7 AMC 150 to 6 CYL dbenford Jeep CJ Forum 2 05-11-2002 12:29 PM
