Quantcast 1986 CJ7 6 cyl 4.2 auto. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1986 CJ7 6 cyl 4.2 auto.
Old 03-27-2009, 09:22 AM   #1
ALA650LE
Does any one have the spec on this model, thinking about buying one. It needs some work.
Also what trans does it have in it. Someone told me it was a Dodge trans. and will a Mopar engine bolt up.
thanks
ALA650LE is offline   Reply With Quote
Old 03-27-2009, 10:12 AM   #2
texasdave
texasdave's Avatar
1980 CJ7
Is it original? Sometimes what they start out as isn't what ends up in them.
texasdave is offline   Reply With Quote
Old 03-27-2009, 10:23 AM   #3
jaysonmatt
Can't help with specs on the jeep, but this site has helped me with any and all components inside.
http://www.geocities.com/cantwait_forviolence/nav.html
jaysonmatt is offline   Reply With Quote
Old 03-27-2009, 10:53 AM   #4
Oily
We can be a lot of help but we need your help.
Standard ? Automatic ?
What specs ?
Oily is offline   Reply With Quote
Old 03-27-2009, 11:01 AM   #5
ALA650LE
What specs ?
Automatic 3 speed
Specs on the driveline What ratio from the factory?
Will a dodge V8 bolt to the automatic or do I need extra parts.
Thanks
Old 03-27-2009, 03:14 PM   #6
The Keith
I have an '85 with similar specs. Assuming it's factory, the tranny is a TF999 (Torque Flight) 3-speed auto and yes it is used extensively in MOPARs and will bolt up to some of the motors w/ minimal or no modifications. If you're lucky, the rear diff could be a Dana 44 (square-looking pumpkin) insead of the AMC 20's (round-looking pumpkin) used in previous years. They put them in the last half of that model year. The ratio was 3.31, I believe. (someone correct me if I'm wrong). If you have the AMC 20, the stock gear ratio is 2.73. Your front diff will be a Dana 30 and the transfer case is a Dana 300.
Hope this helps
'85 CJ-7
'02 KJ Limited
The Keith is offline   Reply With Quote
Old 03-27-2009, 03:28 PM   #7
jeepskate
TF-999 3-speed auto...internals are identical to it's Mopar brethren, but that's it...it does *not* bolt up to a Mopar engine, but you can use the aftermarket shifters, pans, shift kits, etc. You can put in a Mopar V8 and matching auto and swap the Jeep output shaft & tailhousing into/onto the Mopar 9xx trans so that the Dana 300 t-case will bolt back up...doing this on my Scrambler project.
Standard ratio is 2.73, 3.31 if it has the towing package.
Dana 30 front, AMC 20 rear with the possibility (somewhat rare) of a Dana 44 rear instead since it's an '86...easy to tell by looking at the diff cover. If it is basically just a plain round dome, it's the AMC 20.
Plenty of ID info here: www.jeeptech.com
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Glock Forum
