Ok gang,
I need help. 1986 CJ-7. They key turns enough to unlock the steering wheel but it will not turn enough to the first detent (accessories on). It will turn counterclockwise (i.e. radio on) but it will not turn clockwise to the accessory on detent or the starter on detent.
almost feels like the rod inside the steering column is jammed up somehow.
I can feel the rod move back and forth on the column when I turn they key.
I dont know if the rod is jammed at the key cylinder or down at the bottom of the column.
Anyone have instructions on how to install a new key cylinder and/or get at
the rod that moves inside the column?
Also, because the steering column can be unlocked, I'm wondering if it would be easier to just install two switches. One for accesories on and the other to start the Jeep. Is that possible using the solenoid on the fenderwell?
Thanks
