1985 CJ7 electrical questions (cut the red wire???) - JeepForum.com
post #1 of 14 Old 08-17-2011, 11:47 AM Thread Starter
nyolles
So I’m starting the tear down of my 1985 CJ7 258 with air conditiong. After ripping out the hack jobs for the radio and the Viper alarm system, I found the wiring was actually pretty clean. After hours of researching JeepForum, wiring diagrams – which I have no experience in reading, and the service manual, I just have a few questions about my electrical system.
I’ve done my research and to try to make things easy, I’ve labeled a few photos from my Jeep. I know there are a lot of questions jammed into a small space, but hopefully you experienced guys can help me.
A – The tachometer even though my Jeep doesn’t have one. My only question is about the note in the wiring diagram that I found saying "4 CYL ONLY". My Jeep has an inline 6. What does this mean?
B – I believe this is for the clock that didn’t come with my Jeep and the connector just needs to slide up and over the steering column to the other side. Correct?
There are no light bulb sockets for A and B though.
C – I think this is for the turn signal flasher despite the fact that the fuse box has a circular place designated for it. Correct? Quadratec and Jeep4x4Center have two parts listed 552 and 224, which do I want?
D – 4 wires (Yellow, Red, Orange, and White) coming through the firewall into the harness on the engine side. I have no idea where these go – absolutely none. This would be my biggest question.
E – air conditioning unit. Discovered goes to the fuse box. Nevermind.
F & G – air conditioning unit. I think it would be safe to assume F connects to G.
H, I & J, - air condition unit. I have no idea where these go. The AC was disabled by the previous owner. I & J were plugged together but that doesn’t seem right. H connects into black (ground?) which doesn't go anywhere, but yellow to black doesn’t seem right either.
K – coming out of the lighting connector, where does this go? 4 wires: Black, Orange, White, & Grey. It kind of looks like the white box horn relay connector which you can see is already plugged into another connector.
L & M – Again out of the lighting connector. Also don’t know where they go.
N – Hood switch was connected into the Viper alarm system. Is this switch stock? Did it go to a hood light or something originally?
I'm going to make Clue like accusation here and say the black wire currently plugged into H, should plug into M and N, and possibly work my mythical hood light??????
J, H, and L (red, yellow, and Orange) are three of the colors of the D group and could go together. But that leaves White in D and the blue I unaccounted for.
Thanks in advance for your help. This is going to be a fun project.
nyolles is offline
post #2 of 14 Old 08-17-2011, 12:09 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Well, only help I can give you is the hood switch. If you have a light under there, you can use it for that. I don't know of many that have lights under there..
Rick
Cutlass327 is offline
post #3 of 14 Old 08-17-2011, 12:43 PM
BioTex
1979 CJ7
"K" may be for the dome light with a hard top
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #4 of 14 Old 08-17-2011, 01:42 PM Thread Starter
nyolles
There's a square connector with two pins on the driver side of the rear corner panel by the tailgate that's for the hardtop dome light. I don't think this is for the hardtop. But considering it's connected to the light switch harness, I assume it's for some other lights.
Thank You,
Nate
nyolles is offline
post #5 of 14 Old 08-17-2011, 02:06 PM Thread Starter
nyolles
OK, after studying the electrical schematics a little more, I found that K is definitely for the OEM fog lights.
nyolles is offline
post #6 of 14 Old 08-17-2011, 03:03 PM
BioTex
1979 CJ7
Glad you got it sorted out...
On my 85, there is a connector that connects the wire harness that runs inside the tub all the way back to the dome light connector you mention.
That connector you have pictured looks to be at about the same location near the driver side kick panel, so that is why I thought maybe it was for the dome.
Don't you just LOVE PO's that snip wires?
I had a brand new car that I took into a shop for a better aftermarket radio.
The guy cut off the factory connectors to wire in the new radio
I could have strangled him on the spot. What a lazy moron!
Currently:
BioTex is offline
post #7 of 14 Old 08-17-2011, 03:06 PM
BioTex
1979 CJ7
Also, I don't think that hood switch is factory. Pretty sure they used a mercury switch built into the light itself. Thinking it is an orange wire that plugs into it IIRC.
Currently:
BioTex is offline
post #8 of 14 Old 08-17-2011, 03:34 PM Thread Starter
nyolles
You know what; I think you're correct. I saw the orange wire in the schematics.
Yeah, sucks. I definitely need to figure out what the 4 wires are at D, and those two at L and M. Looking at the schematics and the workshop manual provided by members on this site, I was able to determine what connectors did what, but random wires are beyond my skill level at this time.
nyolles is offline
post #9 of 14 Old 09-10-2011, 02:33 PM
248107
Guest
1983 CJ7
Don't know if you figured this out yet.
L and M are the courtesy light wires.Orange going to the light and Black going to a door switch for the ground to operate them.
D the 4 wires could be the Tach for a 4 cyl. Black and Orange for lighting and Yellow and Red for the Tach.
There's not to many yellow wires in the wiring.One is 10 gage the others 16.This is just a guess on the four wires
248107 is offline
post #10 of 14 Old 09-10-2011, 09:20 PM
sbsg2005
The hood switch is probably for the alarm that you removed. All my vehicles have alarms that I have installed they they all included a switch like that to set of the alarm if someone opened the hood.
sbsg2005 is offline
post #11 of 14 Old 09-12-2011, 02:45 PM Thread Starter
nyolles
I think you are correct.
nyolles is offline
post #12 of 14 Old 09-12-2011, 02:50 PM Thread Starter
nyolles
I think D was leftover from the alarm.
But, thank you for L and M. Would it be proper to use these two wires to setup a courtesy light inside my Tuffy center console?
Thank you.
nyolles is offline
post #13 of 14 Old 09-12-2011, 10:07 PM
248107
Guest
1983 CJ7
Thank you.
Sure you could use them for the lites in the console.The reason i know there courtesy light is i have them on mine and i'm the original owner.Rig up a switch thats looks like the one under the hood or similiar one and your good to go.
I traced my FSM manual and found a loom of wires like D that went to the tach on a 4 cyl but the four wires do look a little aftermarket type install.
Good Luck Mike
248107 is offline
post #14 of 14 Old 09-13-2011, 08:00 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It means the 6 cylinder hooks up in a different place, just off the ignition switch. I think in the later years many connections were left in the harness to make is simple and then you just hooked up the accessories as you need them.
The power for the lights for the clock and tach were on a separate harness not included in the main harness it came off the fuse box.
I think your right, only the hazard flasher was left in the fuse box. I think on the left side. I'm not sure which to use, I never look at that stuff anyway.
Does it come through the firewall plug or just a hole in the fire wall. If NOT through the firewall plug then it may be POLOS ( Previous Owner Left over Stuff)
I have an AC unit at home, I'll have to look at it.
To a separate harness for fog lights. It comes out of the Light plug because the driving/fog lights only come on when low beems are on.
Dome or Courtesy lights
Real fun...
John Strenk is online now
cj7 , electrical
Questions about an 1985 CJ7? AEK Jeep CJ Forum 4 08-12-2011 08:42 PM
1985 CJ7 electrical plugs near battery nyolles Jeep CJ Forum 2 08-10-2011 11:16 AM
1985 CJ7 Questions abernut Jeep CJ Forum 32 06-17-2010 12:08 PM
Electrical questions adman02 Jeep CJ Forum 6 03-18-2010 09:05 PM
Questions CJ-7 1985 Kjell Lindberg Jeep CJ Forum 6 01-11-2002 05:13 PM
