1985 CJ7 Auto Transmission Column - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1985 CJ7 Auto Transmission Column
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread Yesterday, 08:45 PM   #1
jandbkrause
Does anyone have a picture of the bottom of their 1985 CJ7? I have a major leak and I think its a little red and black. So two fluids slowly leaking. When I took off the Trans plate the trans lowered about 2 inches so got nervous and put the jack under the Trans. I'm not sure how to find these leaks and how to repair. I do see a briddle/broken gastket right under the Trans Plate where one of the nuts screw on. Could that be an issue. Is rectangle about 1 inch by 3 inches. Thoughts? Thanks so much for the help.
Extreme Rookie,
Jason
jandbkrause is offline   Reply With Quote Quick reply to this message
