1985 CJ7 - adding clock and tach - is it wired? - JeepForum.com
post #1 of 7 Old 04-25-2013, 11:16 PM Thread Starter
VanHermanator
My 1985 does not have the clock and tach. I've got the specs to drill out the dash holes and have the gauges ready. Should I expect the factory wiring for these 2 gauges to be there in the harness and just not connected?
Thanks!
VanHermanator is offline
post #2 of 7 Old 04-26-2013, 03:27 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Kind of.
There is a plug for the OEM tach to operate right off the ignition switch but you need to wire up the lights to illuminate it.
The clock also needs to be wired in. There is a harness for both of these connections if you can locate one.
Can't find a picture of the harness
John Strenk is offline
post #3 of 7 Old 04-26-2013, 09:58 PM Thread Starter
VanHermanator
Thank-you John!!! Very much appreciated.
post #4 of 7 Old 04-26-2013, 10:08 PM
PROJECT 23
If you have an OEM clock, I have an extra harness.
PROJECT 23 is offline
post #5 of 7 Old 04-27-2013, 08:48 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Hey John, for folks that have done Rush, nutter and CDI wouldn't they have to use the CDI tach wire? I think I might have cut and taped the tach wire for the CDI??? I don't have the tach. Just picking your brain for those that might
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #6 of 7 Old 04-27-2013, 10:47 AM
John Strenk
1976 CJ5
I'm not sure about the CDI but the "Rush", "nutter" and HEI can use the stock tach but don't hook it up to the "tach" plug on the HEI.
You may need to run an adapter for the CDI
post #7 of 7 Old 04-27-2013, 12:12 PM
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
At least my StreetFire CDI has a tach output wire. I just don't know if it will work with the factory tach.
HALOjmpr is offline
