1984 jeep cj7 360 swap - JeepForum.com
post #1 of 8 Old 08-10-2013, 06:34 PM Thread Starter
geraldfrasl
could use some help here I have a 1990 360 out of a grand wagoner and trying to bolt it in my 1984 cj 7 and for some reason it is just not bolting I have the v-8 stands and no matter what I do it just wont bolt in... the engine is too far back. iam running the t176 trans and the 360 please can someone tell what I can do?
geraldfrasl is offline
post #2 of 8 Old 08-10-2013, 07:30 PM
John N
1981 CJ8
What motor mounts are you using? I used the MORE Bombproof mounts, they located the engine just right. It bolted up just fine to my TF999. Mine is an '81.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 8 Old 08-10-2013, 07:33 PM
paveland
Which engine "stands" are you using? I believe the drivers side is the same regardless if its a L6 or V8, but the passenger side has to be changed to the V8 style. I may have that backwards.
Also the mount should have three different holes on each side that allow you to move the engine forward or backwards.
paveland is offline
post #4 of 8 Old 08-10-2013, 07:33 PM
LeePrather
1978 CJ5
X2 on the motor mounts. I did a swap to 360 from 304 and tried to use the mounts from the 360. The full sized vehicles have different motor mounts. I used my 304 mounts and had it in under a minute
LeePrather is offline
post #5 of 8 Old 08-10-2013, 07:42 PM Thread Starter
geraldfrasl
360 motor mounts thanks I will try that
post #6 of 8 Old 08-10-2013, 07:49 PM Thread Starter
geraldfrasl
i looked the motor mounts up and thay are the same for the grand wagons and the cj or you mean the stands? iam using the cj v-8 stands it just wont bolt
post #7 of 8 Old 08-10-2013, 08:10 PM
arkiemurph
Just to the left and down from the brake booster, I had to bend some sheet metal. I don't know why it's there, but it sticks out about an inch. This was encountered when I was putting a 304 in my 85. Also there's a thread under the "stickies" on v8 swaps into CJs. Good luck!
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #8 of 8 Old 08-10-2013, 08:12 PM
arkiemurph
http://www.jeepforum.com/forum/f8/of...thread-377983/
