1984 CJ7 Vacuum - JeepForum.com
post #1 of 14 Old 04-17-2011, 08:43 PM Thread Starter
gary4569
1984 CJ7 Vacuum
Original vac diagram
Does any one know what and where the port connected to the distributor is located?
I found the diagram above, but I am unsure what the vac advance hooks to.
gary4569 is offline
post #2 of 14 Old 04-18-2011, 06:05 AM
Mike Romain
Looks like you have one of the funky ones that mixes ported and manifold vacuums so your distributor line has a t fitting on it that goes to a round vacuum module one way and around to the brake fitting likely on the other side of the t fitting with one more t off to the switches on the top back of the valve cover.
The round vacuum module has a line going to the valve cover side nipple on the carb with a T along the way running down to the charcoal canister purge signal on the fender.
If you want it simple, the distributor can be plumbed with a T fitting to pick up the canister line and then go direct to the side carb port. You will need that vacuum delay valve in there too though I think. That would disable a part of the emissions system though.
Mike
Mike Romain is offline
post #3 of 14 Old 04-18-2011, 07:05 AM
mcmud
1983 CJ8
There is no mixing of vacuum advance sources in that diagram.
This one is shown plumbed direct to manifold vacuum, see the fitting just below the EGR label.
It will be this one. http://home.sprynet.com/~dale02/m.htm
mcmud is offline
post #4 of 14 Old 04-18-2011, 06:29 PM Thread Starter
gary4569
The po had connected the vac advance to the port labeled E
And disconnected the egr system and vac canister
I want to put all back as factory had installed it.
gary4569 is offline
post #5 of 14 Old 04-18-2011, 08:28 PM
mcmud
1983 CJ8
If you're working on your '84 CJ this diagram may be more accurate. The two are similar however this one utilizes a 5 nipple dual CTO.
mcmud is offline
post #6 of 14 Old 04-18-2011, 08:43 PM Thread Starter
gary4569
Thanks. My cj7 has the two port cto
gary4569 is offline
post #7 of 14 Old 04-19-2011, 08:35 AM
Mike Romain
If you carefully follow the lines to the bottom of the diagram you will see the vacuum sw asm that is plumbed to the S port on the carb and to the distributor line. This is a vacuum mixer that mixes ported and manifold vacuums from what I have read up on. I have seen them on several engines.
Mike
post #8 of 14 Old 04-19-2011, 08:41 AM
Mike Romain
Do you have the missing pieces? I am thinking that vacuum diverter valve or vac. sw.asm. They are about 2" round and 1" deep and usually sit someplace behind the carb. Usually the long vacuum line going to them is steel. They have strange looking ribs on them if I remember right. Some photos of what you now have can sure help.
The canister is important to have working, it is the gas tank vent. It also has a $2.00 air filter for the bottom of it most folks don't know about. the first filter is a bear to dig out, but after that new ones just tuck in and out.
Mike
post #9 of 14 Old 04-19-2011, 08:46 AM
mcmud
1983 CJ8
No, that assembly doesn't mix the signals.
Each is independent of the other.
They translate both the ported as well as the manifold vacuum signal strength into electrical current and that is sent as input to the computer.
The 4 & 10" vacuum switch assembly acts as a throttle position sensor.
mcmud is offline
post #10 of 14 Old 04-19-2011, 08:54 AM
mcmud
1983 CJ8
Here is a link that may clear up some often stated misunderstanding of the CJ vacuum system.
http://home.sprynet.com/~dale02/vacuum.htm
mcmud is offline
post #11 of 14 Old 04-19-2011, 09:14 AM
Mike Romain
I am thinking another flavor of emissions then, sorry.
Mike
post #12 of 14 Old 04-19-2011, 09:38 AM
Mike Romain
One more thought, if you are missing parts, just ask on this forum and you should find them easily. Lots of folks are removing most of the emissions systems and manually tuning them up. See: How to - Nutter Bypass - JeepForum.com
Mike
post #13 of 14 Old 04-19-2011, 07:07 PM Thread Starter
gary4569
It looks like all pieces are still intact. I will have to check on the vac sw asm now that I know where to look.
I just bought this CJ and will have to do emissions testing when I register it. That is why I am trying to get all of these things hooked back up.
Thanks for all the help... These vacuum/emission systems seem overly complicated.
gary4569 is offline
post #14 of 14 Old 04-19-2011, 09:05 PM Thread Starter
gary4569
It does have the vac sw asm, but it is not hooked up. No F/delay or in line vac reservoir. Is this a critical system. What is it's function?
If I connect the vac advance to the correct port (M), does the vac sw asm have to be connected?
gary4569 is offline
emissions , vacuum advance , vacuum lines
MC2100 AMC360 Help with Vacuum port and Vacuum leak 4lowherewego Jeep CJ Forum 40 01-30-2011 08:03 PM
1984 Cj Fsm ClarkGriswold Jeep CJ Forum 0 10-06-2008 08:58 PM
1984 Cj-7 ChadCielencki Jeep CJ Forum 12 12-05-2007 01:29 PM
1984 Cj7 onesourcemike Jeep CJ Forum 3 04-05-2006 10:18 AM
1984 CJ Value? roscoefiftysix Jeep CJ Forum 8 12-15-2004 01:45 PM
