1984 CJ7 Rebuild (Pic heavy) - Page 3 - JeepForum.com
post #31 of 78 Old 08-03-2013, 03:52 PM
Loorider
1969 CJ5
I heared you need a special kit to mount a poly body on to your frame for extra strength. For my CJ5 I've got a poly body with plywood reinforcements. I am planning on making a bushing with steel plates of 4 inches on the inside and outside of the body. What is advised with your body?
Loorider is offline
post #32 of 78 Old 08-05-2013, 06:51 AM Thread Starter
j33pman
I'm not sure what is advised with mine, I got it used from guy on Craigslist. I know the 4WD Hardware bodies use a special system between the 2nd and 3rd body mounts. This is is much heavier at all mounting points, my plan it to just drill holes as needed and use the factory locations
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #33 of 78 Old 08-05-2013, 07:00 AM Thread Starter
j33pman
OK, big progress weekend. I did a little research and most people say not to sand metallic paints. I picked up a bottle of Meguiars Ultimate Polish and went to town on the whole body. I probably should have used something a little coarser, I don't feel like this did any cutting at all. It looks nice though, so that's good enough for me.
Remember, I'm building a trail rig, not a show rig. The paint will end up scratched at some point, there is no way to avoid it.
I finished fixing a couple of runs Friday night, Saturday I did two coats of polish over the whole Jeep and then taped it off to spray bedliner on sunday.
Sunday I vacuumed out any dust and loose crap inside the tub and sprayed UPOL Raptor. This stuff turned out great!
I sprayed my first coat at 40 psi, but I wanted a little more texture, so I sprayed the second coat at 30 psi, all pictures show the final coat, sprayed at 30 psi.
I waited about an hour to peel my tape off.
Bill H. - 1984 CJ-7
j33pman is offline
post #34 of 78 Old 08-05-2013, 11:58 AM Thread Starter
j33pman
Originally Posted by JeepGuy66 View Post
Looks great! Any reason you chose Upol over, say Monstaliner?
I think the raptor has been around longer.
I have seen more info and reviews on it. My dad sprayed his dump box in his truck with it about 4 years ago and it still holding up great.
Plus is costs less than monstaliner
Bill H. - 1984 CJ-7
j33pman is offline
post #35 of 78 Old 08-12-2013, 07:51 AM Thread Starter
j33pman
Painted the steel parts this weekend-
This week I can finally start assembly and wiring!
Bill H. - 1984 CJ-7
j33pman is offline
post #36 of 78 Old 08-12-2013, 03:44 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Nice werk!
My newest build:
Necromancer_tat is offline
post #37 of 78 Old 08-15-2013, 05:47 PM
josh_br
2003 WJ
Great work man. It's coming along nice!
Josh_Br
2003 WJ (Laredo), 1990 Toyota pickup
Used to have a couple TJ's and ZJ's
josh_br is offline
post #38 of 78 Old 08-16-2013, 07:27 AM Thread Starter
j33pman
Last night I got my roll bar painted and used some old scrap material I had laying around to build a grinder stand for my wire wheel
Bill H. - 1984 CJ-7
j33pman is offline
post #39 of 78 Old 08-19-2013, 09:06 AM Thread Starter
j33pman
Crappy picture, but I got the body positioned and the fenders / grill mounted.
Not shown in picture, but I now have the front and rear body mounts done as well as the grill mounted.
Bill H. - 1984 CJ-7
j33pman is offline
post #40 of 78 Old 08-21-2013, 06:55 AM Thread Starter
j33pman
Spent the last two nights working on body mounts. Last night was mainly designing the roll bar tie in point/body mount.
I didn't take any pictures, I will get some tonight, I should have that mount position finished tonight. Then I start the rear tie ins for the roll bar.
Bill H. - 1984 CJ-7
j33pman is offline
post #41 of 78 Old 08-22-2013, 10:16 AM
WhiskeyCity
I am sooooo jelly!
WhiskeyCity is offline
post #42 of 78 Old 08-23-2013, 07:00 AM Thread Starter
j33pman
ok, last nights progress.
Got my Aluminum corners back on
Finished up the bodymount/roll bar tie in point
body side
the plan is to bolt each end of the "wings" to the roll bar, sandwiching the body in between them.
The center hole is drilled up through the body and through the roll bar and will use a 1/2" bolt to attach the roll bar/body to the frame side mount.
also worked on putting lights back in the grille. It's actually starting to look like a Jeep again!
I'll have the grille done on Saturday with the radiator mounted, I need to figure out something to use as a screen to hide the electric fans , but I want it behind the grille slots.
Bill H. - 1984 CJ-7
j33pman is offline
post #43 of 78 Old 08-27-2013, 08:29 PM Thread Starter
j33pman
Tonight I got the body mounts that I was working on done and installed.
Passenger side
Driver side
Also put my fuel filler and hoses back in
and mounted the battery box
Tomorrow is pedal box, brake booster/master Cylinder and Probably some of the heating system
Bill H. - 1984 CJ-7
j33pman is offline
post #44 of 78 Old 08-28-2013, 02:54 PM
Loorider
1969 CJ5
I like the way you sandwich the body between the rollbar and the bodymount. I think I steel your idea!
Loorider is offline
post #45 of 78 Old 08-28-2013, 02:57 PM Thread Starter
j33pman
Be my guest, I forgot to take a picture of the top side, I will get that tonight.
I used a 1/2" bolt and custom cut 3/16" thick washers for all body mount locations
Bill H. - 1984 CJ-7
j33pman is offline
