1984 CJ7 Rebuild (Pic heavy) - JeepForum.com
post #1 of 78 Old 07-05-2013, 09:30 AM Thread Starter
j33pman
Last summer I started tearing down my '84 CJ7 for a rebuild with frame repairs and a fiberglass body. I will use this thread to try to keep everyone up to date on the rebuild progress.
This will end up being a picture heavy thread!
This is the last known picture of my Jeep and I before I started tearing it down.
Hood, fenders and grille removed
Here they are sitting next to the Jeep.
After removing the body bolts, I lifted the Body off using the trusty Farmall H
Picked the body up and rolled the frame out from under it
Here is the body sitting on the ground
the body was so weak it started buckling when it was picked up!
Frame and drivetrain sitting on its own.
this is the condition of the rear ends of the frame rails
I cut all of the rot out.
Used the tractor again to pull the drivetrain out
I didn't take any pictures of taking the axles and stuff out, but here it is in bare frame rails about to get sandblasted
Blasted and primed
Most of the body mounts look like this, so I made new ones and welded them in
Here's one after replacement
I spent most of a day making this framerail pieces for the back
Got them welded in good and solid
Here is the frame all painted up after I completed the repairs
2 coats of primer, 2 coats of Rustoleum enamel paint, 2 coats of rubberized undercoating.
Axles back in
No pictures, but before I had to abandon it for the winter, I got the drivetrain back in and set the body on and put two bolts in it to hold it in place.
So that brings us to this year!
I decided to go with tube fenders because mine were rusted pretty badly.
Ordered from CCFabs, I love these so far, they look really beefy and were far cheaper than some "popular" brands.
My Factory inners were pretty rough, so I bought some 22 gauge steel and fabbed my own inner fenders
started sandblasting my grille and found the lower part where it mounts to the frame was pretty rough
So I cut it off and made this from some steel I had laying around
I made a makeshift paint booth in the barn to paint in and started throwing some primer on my steel parts
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #2 of 78 Old 07-05-2013, 09:31 AM Thread Starter
j33pman
Yesterday I started making a mount for my antiwrap bar, this is as far as I got before I had to go to a BBQ
More to come soon!
Bill H. - 1984 CJ-7
j33pman is offline
post #3 of 78 Old 07-05-2013, 09:34 AM Thread Starter
j33pman
Here is an album on imgur or my inner fender build
http://imgur.com/a/EHuqj
Bill H. - 1984 CJ-7
j33pman is offline
post #4 of 78 Old 07-05-2013, 09:35 AM
pman
You had me at "Pic Heavy". Subscribed. Looking good; nice fab work!!!
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #5 of 78 Old 07-05-2013, 09:46 AM Thread Starter
j33pman
Thanks!
I don't consider myself in any way to be a "great" welder, but I'm not building a show piece, it just needs to hold up.
Over the winter my father and I bought a Lincoln ProMig 180 from Lowe's. that makes the job a lot easier than the old buzz box!
Bill H. - 1984 CJ-7
j33pman is offline
post #6 of 78 Old 07-05-2013, 10:23 AM
pman
Originally Posted by j33pman View Post
Thanks!
That's a good setup for what you are doing! I'm no pro welder either, but have really enjoyed making repairs with it; sure does give you one more piece of freedom from "the man"!!
pman is offline
post #7 of 78 Old 07-10-2013, 06:06 AM Thread Starter
j33pman
I managed to get some work done last night, and even remembered to take a few pictures. a couple of them are a little dark.
I spent my night working on my anti-wrap bar, trying to finish designing and building that. It started raining, and I am working outside, so it didn't get done. As long as it doesn't rain tonight, I should be able to finish it.
On sunday I welded endcaps on my crossmember for the anti-wrap bar
I used this cheap Harbor freight tube notcher to notch the tubes for my anti-wrap bar. It's not quite center, so it needed a little tweaking.
Axle plates welded in
The bushing for the shackle on the front will attach to this point
This is a weld-in threaded fitting that came with the anti-wrap kit from Ballistic fab
A Heim joint will thread into this and use high-misalignment spacers to allow for articulation at the shackle end
Here is a picture of the top tube for the anti-wrap completed.
Hopefully more work gets done tonight with some more pictures tomorrow.
Bill H. - 1984 CJ-7
j33pman is offline
post #8 of 78 Old 07-10-2013, 09:42 AM
S76
Nice Work!
Subscribed.....
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #9 of 78 Old 07-10-2013, 04:00 PM
lukenicwalker
1982 CJ7
Forgive my ignorance on the subject - is your "antiwarp" bar the same as what some call a torsion bar? Just trying to figure out how to fix my SOA so it is right. Thanks!
Looks good, by the way!
ldw
lukenicwalker is offline
post #10 of 78 Old 07-10-2013, 07:54 PM Thread Starter
j33pman
I did a quick google search and I don't think it's quite the same, I have seen the term "ladder bar" used to refer to them as well.
Bill H. - 1984 CJ-7
j33pman is offline
post #11 of 78 Old 07-10-2013, 07:59 PM Thread Starter
j33pman
I managed to get the anti-wrap bar finished up tonight, I didn't get it painted because I am considering whether or not I needed to add an additional brace inside the structure for extra strength.
Here's a close up of the one weld, I'm pretty happy it.
Bill H. - 1984 CJ-7
j33pman is offline
post #12 of 78 Old 07-10-2013, 08:38 PM
skizriz
1978 CJ7
Easy enough to do, and it Sure wouldnt hurt.
Overkill is just about enough.....
Nice work. Its coming along.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #13 of 78 Old 07-11-2013, 05:58 AM Thread Starter
j33pman
True, It definitely won't hurt and is far easier to do now than later.
I won't get a chance to do it tonight (Jeep Club meeting) but I will fit it up tomorrow and take some pictures
Bill H. - 1984 CJ-7
j33pman is offline
post #14 of 78 Old 07-15-2013, 05:58 AM Thread Starter
j33pman
Got the anti-wrap bar completed
Also got my exhaust re-ran since I realized that the muffler was going to be in the way of the e brake cables and also hang too low for the anti-wrap bar crossmember
Bill H. - 1984 CJ-7
j33pman is offline
post #15 of 78 Old 07-22-2013, 09:00 AM Thread Starter
j33pman
I didn't get too much done with weekend, spent Saturday sanding and prepping the fiberglass body for paint.
Bill H. - 1984 CJ-7
j33pman is offline
