1984 CJ7 question - JeepForum.com
post #1 of 3 Old 07-31-2011, 10:22 PM Thread Starter
gary4569
1984 CJ7 question
Stock suspension 1984 CJ7.
What effect would factory size 235/75/15 tires have on loose steering that does not return to center.
Currently have 31x10.5 all-terrain on a wider wheel which drive much better that the mud tires I have on the factory wheels.
I have the factory Laredo 15x7 wheels and I am thinking of putting stock tire size on them, but don't know how steering will be effected.
gary4569 is offline
post #2 of 3 Old 07-31-2011, 10:49 PM
BagusJeep
1981 CJ7
That tyre is around 29" so you will reduce from 31" back down to 29" with what sounds like reduced offset.
Steering is affected by a number of measurements including caster angle. Changing the tyre and wheel size will change those measurements and angles and will have an effect upon self centering. However a 31" tyre is not a massive change so it may not be the total explanation.
If you want to get the centering back with 31" tyres you will have to have the geometry measured, work out what you need and get it changed. It sounds like you do not have enough caster, but best get it checked before going in and changing anything.
I am not sure what you mean by "loose". If there is excessive play in the steering, especially worn bushes, you will struggle to get a level of handling and self centring. If in doubt I suggest you get it checked and fixed before you spend any money.
The A/T will drive better than the M/T, they are more road biased. Not brilliant off road but you know that.
If your suspension is still correctly aligned for the factory tyres (a big iff on a 27 year old vehicle) you will notice a slight improvement when you change. I suggest strongly you have a proper 4 wheel alignment check before buying new tyres, you may find the results interesting.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 3 Old 08-01-2011, 05:32 PM Thread Starter
gary4569
No play in steering. Very easy to turn the steering wheel. Tends to wander especially on old uneven roads. Better with all-terrain tires. Drives pretty good on interstate highways.
Also noticed the front axle is a little off center. One tire sticks out of fender a little more that the other.
gary4569 is offline
cj7 , laredo , steering , tires. tire
1984 Jeep CJ7 question.... ImBroken Jeep CJ Forum 11 09-28-2013 06:34 AM
1984 CJ7 2.5 AMC - Carb & intake question cpop Jeep CJ Forum 8 07-27-2011 10:22 PM
1984 CJ7 Vacuum Advance question gary4569 Jeep CJ Forum 8 04-24-2011 09:22 PM
1984 CJ-7 with Chevy 350 Temp Question kev12 Jeep CJ Forum 6 08-18-2010 08:37 PM
Simple Oil Pan question (CJ7-1984) machacker1 Jeep CJ Forum 5 01-02-2006 08:59 AM
