1984 cj7 air conditioner compressor bypass pulley - JeepForum.com
post #1 of 14 Old 03-08-2016, 08:44 AM Thread Starter
MTGrizzlies
I have an 84 cj7 with the 258. It came with an air conditioner. I removed the air conditioner and would love to remove the compressor. Does anybody know if there is a pulley that will mount to the compressor bracket? If not, can you just remove the bracket and compressor and purchase a shorter belt? If so, anybody have a belt part number?
MTGrizzlies is offline
post #2 of 14 Old 03-08-2016, 09:33 AM
John Strenk
John Strenk's Avatar
1976 CJ5
THere is and they come up on eBay every so often.
I think it's called an "AC Delete Bracket assembly"
Might be used on YJ's also..
John Strenk is offline
post #3 of 14 Old 03-08-2016, 11:16 AM Thread Starter
MTGrizzlies
Thanks, I will start looking on eBay and maybe look at some of the junk yards. I assume you can replace the bearings in it?
post #4 of 14 Old 03-08-2016, 04:56 PM
scooby533
Just my two cents, I wanted AC and found a member who did not. I paid for all the shipping and he swapped me everything; pulleys, brackets, compressor and under dash unit.
Shawn
scooby533 is offline
post #5 of 14 Old 03-08-2016, 05:15 PM Thread Starter
MTGrizzlies
Interesting idea scooby533. I would be interested in this if anybody had an ac delete bracket assembly?
post #6 of 14 Old 03-08-2016, 10:10 PM
258
I have this set up which simply requires the longer belt. (I use Gator)
The bearings are EASY to remove. Secure the pulley and gentle tap them out with a wooden dowel.
I would recommend replacing the bearings because the original pulleys are metal, not plastic.
Replacing them eliminated so much of that engine bearing noise as well.
258 is offline
post #7 of 14 Old 03-09-2016, 03:40 AM
John Strenk
1976 CJ5
You could also just turn the the AC compressor into an air pump to fill up your tires or run some air tools.
post #8 of 14 Old 03-09-2016, 06:58 PM Thread Starter
MTGrizzlies
Does anybody have an extra ac delete bracket assembly?
post #9 of 14 Old 03-09-2016, 07:19 PM
258
That may be a tough find. Here is a the PART NUMBER to help you narrow your search.
# 8933-000-450
258 is offline
post #10 of 14 Old 03-09-2016, 07:38 PM
78redcj7
1978 CJ7
# 8933-000-450
Agreed, from what i understand they were Califorina only, i fell over one in Central Florida and bought the whole front of the engine for $100. Which didnt include a compressor, just the bypass. I love love love the serp setup as i can run a 100 amp altenator off of it
I may have it laying around i will c heck to see if i still have one.
78redcj7 is offline
post #11 of 14 Old 03-09-2016, 07:44 PM
258
Sometimes it's better to buy whatever a seller is selling just to get a small part you need. In other words, if you need a part that's hard to find, GRAB IT regardless.
I too run the Delco-Remy 12si 100(94)AMP alternator with a serpentine belt. The image is with my OEM stock 64 AMP so; it's been upgraded. Love the newer 12si.
258 is offline
post #12 of 14 Old 03-09-2016, 10:27 PM
lucdog
lucdog's Avatar
1980 CJ5
It may be a lot easier to completely remove everything compressor related and find the correct alternator bracket for a engine without AC.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 14 Old 03-10-2016, 08:36 AM
PERK
where mite the OP be located?..I think I got one..
PERK is offline
post #14 of 14 Old 03-12-2016, 09:29 AM Thread Starter
MTGrizzlies
You guys have such great information. Perk I am located in Helena MT
