1984 CJ Steering Column Help - JeepForum.com
post #1 of 8 Old 03-06-2012, 04:19 PM Thread Starter
8jeep4
1984 CJ5
Hey I am new to this page, I have a 1984 CJ5.
Runs great, the only issue is, I lost the keys not too long away and since then had been jimmy rigging it. Well one day it wouldn't start and I haven't been able to get it to start then. I tried taking out the whole column but couldn't get it to work, anyone have an idea what it may be? I am thinking either the ignition cylinder or the whole column... any help would be appreciated!
8jeep4 is offline
post #2 of 8 Old 03-06-2012, 05:28 PM
248107
1983 CJ7
Everything about columns is in this thread Either by the posts or links inside the posts.
http://www.jeepforum.com/forum/f8/ti...lease-1294496/
248107 is offline
post #3 of 8 Old 03-06-2012, 05:33 PM
jimdubose
1978 CJ5
I agree with the above post, but also, click this URL:
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
good pictures, explanations on how to replace, repair. John Strenk also has one but i don't have that link at my fingertips
jimdubose is offline
post #4 of 8 Old 03-06-2012, 08:44 PM
mopar346
Pull the igntion switch off the bottom of the column and plug it back up, take a small screwdriver and move the slide with the screwdriver all the way forward, it should start if it doesn't then you have either a bad ignition switch or it is something in the wiring, either way unrelated to the column or the key and tumbler. If it does start then it is in the column or key and tumbler, my guess would be the rack and sector gear which you can read about in the thread posted.
BE AWARE that when you move that slide it may start if everything is working SO MAKE SURE IT IS IN NEUTRAL!!!
Careful your character's showing
mopar346 is offline
post #5 of 8 Old 03-06-2012, 09:39 PM
BagusJeep
1981 CJ7
Replace the ignition switch, it is quite easy and takes about 30 minutes if you dismantle the column. The only special tool you need is the steering wheel puller but you can make one out of two bolts, 4 nuts and a thickish piece of steel with two holes in. The lock is less than $20.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 8 Old 03-06-2012, 09:49 PM
mopar346
Don't forget about the lock plate tool.
Bagus, not to step on your toes but the ignition switch is the electrical portion down on the outside of the column, the key portion in the column is called the key and tumbler assembly and the gear in behind it and the one the rod attaches to is the rack and sector. I figure you know this and just mistyped, I didn't want the OP to get confused.
Any by the way 8jeep4, welcome to the forum.
mopar346 is offline
post #7 of 8 Old 03-07-2012, 02:23 AM
BagusJeep
1981 CJ7
Ooops, you are absolutely right, I meant the ignition LOCK which as you state is the key and tumbler.
I just replaced another one as I lost the key, and don't ask me who lost the SPARE which was locked in the safe....................
post #8 of 8 Old 03-07-2012, 03:38 PM Thread Starter
8jeep4
1984 CJ5
Thanks everyone, I will look at those threads and try messing around with it, I will keep you all updated.
8jeep4 is offline
1984 CJ7 Steering gary4569 Jeep CJ Forum 21 02-24-2014 08:39 PM
SHORTER tilt steering donor for a 1984 CJ7 drespecki Jeep CJ Forum 0 11-19-2011 05:55 PM
Steering column options for column mounted shifter... HeepToJeep Jeep CJ Forum 7 06-01-2011 07:59 AM
key realease on 1984 cj 7 non tilt column LGTWhisky Jeep CJ Forum 3 11-07-2010 01:32 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 07:16 PM
