1984 CJ-7 Steering Box Assembly is dead and need a new one - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1984 CJ-7 Steering Box Assembly is dead and need a new one
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-01-2012, 12:46 PM   #31
har99
1979 CJ7
Along the same lines of WM69 question above. Can you measure the diameter of the front of the box? We want to see if the piston is larger then the J20 boxes. A little late now but the J20 boxes are a lot cheaper then a H1!
har99 is offline   Reply With Quote
Unread 07-01-2012, 12:48 PM   #32
diddy2003
I am going to have to check that out. I guess we could just cut a spacer out of some steel and make something work. I was hoping someone with my mount would post up with the pics of what they did. Tomorrow I will see what I can find out. Thanks. Maybe MORE even has a spacer to fix the issue?
diddy2003 is offline   Reply With Quote
Unread 07-01-2012, 12:50 PM   #33
diddy2003
How much is a "new" remanned J20 box? I actually thought I got a great price on the H1 box.
Unread 07-01-2012, 01:40 PM   #34
har99
1979 CJ7
O' Reiley's is showing 119 with a 45 core. But I have heard you must check what you get to make sure it is a true 4in diameter, as somtimes they stick a smaller piston box or one with 3 mounting holes instead of 4. Thats why Im wondering the size of the H1 It may be worth it to know what your getting. Here are a few links on here I have found on the J20 swap. If anyone is intrested:
http://www.jeepforum.com/forum/f8/25...r-box-1211170/
http://www.jeepforum.com/forum/f8/j2...grade-1342982/
Unread 07-02-2012, 07:46 AM   #35
MontaukMan
1977 CJ5
I put in the AGR Superbox 2 and pump about 3 months ago and am very happy. World of difference. I had manual steering before, so cant compare to another box but love it so far. I run 35's and lockers front and rear. Just my 2cents
MontaukMan is offline   Reply With Quote
Unread 07-02-2012, 10:00 AM   #36
diddy2003
Originally Posted by VACJ7 View Post
Is this mounted correctly? I know the OEM bracket sandwiches the hanger between the mount and frame. Something about this does not look right.
I just got off the phone with M.O.R.E and they assured me that I installed it the correct way. He said that I would have absolutely no problems. We will see . . . . .
Unread 07-02-2012, 10:09 AM   #37
VACJ7
Hockey Rules!
VACJ7's Avatar
Cool! Glad to know.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote
Unread 07-02-2012, 04:46 PM   #38
VACJ7
Hockey Rules!
VACJ7's Avatar
Just FYI, I still have my old CJ gear box and just going off the end cap OD size the H1 gear is larger. Measures 4.25 OD and the CJ box end cap is like 3.75.
Unread 07-02-2012, 07:05 PM   #39
diddy2003
I wasn't able to measure the difference yet between the two. Thanks for the post. The H1 box is definitely bigger than the OEM unit. Much heavier duty looking. The new lines should be In tomorrow so hopefully everything works out and I can give a road test review.
Unread 07-06-2012, 11:28 AM   #40
waterdowg
So how did it work?
waterdowg is offline   Reply With Quote
Unread 07-06-2012, 12:57 PM   #41
diddy2003
Haven't driven it yet but just sitting in the garage bay its much better. No flexing on the output shaft and no leaking. Everything went right in. New warrior products hangers too.
Unread 07-06-2012, 12:59 PM   #42
diddy2003
The one that broke.
Unread 07-06-2012, 02:22 PM   #43
har99
1979 CJ7
http://www.jeepforum.com/forum/f8/j2...62/index2.html
The #19 post in this links states the H1 box is backwards, can you confirm if this is true or not? Does your steering work correctly?
Unread 07-06-2012, 02:39 PM   #44
diddy2003
Worked just fine.
Unread 07-06-2012, 06:33 PM   #45
waterdowg
Originally Posted by diddy2003 View Post
Worked just fine.
Great, The claim on that thread was that your steering would be backwards. So if you turned the wheel to go right the jeep would go left.
cj7 , steering , steering box
