1984 Cherokee axles in 1979 CJ5? - JeepForum.com
post #1 of 5 Old 02-18-2010, 07:59 PM Thread Starter
CJ579
Just as the title states, will it work? I tried to do a search, but no luck with that year model, I can weld on the spring perches and use the springs on the cj, just wondering if any one had done it? I just blew the rear axle apart and have a cheap 84 cherokee I can get the axles out of
CJ579 is offline
post #2 of 5 Old 02-18-2010, 09:21 PM
78treehugger
1980 CJ7
I believe that the front axle is a driver's side drop. And the rear will either be a Model 20 or Dana 44, I think they were Model 20s. Is you jeep an automatic or manual? The rear may or may not have an offset differential also. Take that into account.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #3 of 5 Old 02-18-2010, 09:29 PM Thread Starter
CJ579
My cj5 is a 3spd, the donor jeep is a 5spd, I havent had a chance to look at it yet, i dont know what side drop the front axle is, thats what i was hoping to find out...
CJ579 is offline
post #4 of 5 Old 02-19-2010, 01:40 AM
jumbojeepman
1976 CJ7
Are we talking little Cherokee or big Cherokee (84 is right around the period they switched.) Either way, it will be a driver's side drop (the later SJ's switched sides from the earlier ones, and don't have an offset rear axle at all, no matter what transfer case. I used to have an 82 SJ Cherokee.) If it's an XJ it's definitely a driver's side drop.
jumbojeepman is offline
post #5 of 5 Old 02-19-2010, 02:48 PM
Pathkiller
1974 CJ5
84 would be an XJ (small Cherokee), the last year of the fullsize was 83. This would be one of the most pointless and ill-advised axle swaps I could possibly think of. The front axle in the XJ would be completely wrong for a CJ, besides having the pumpkin on the wrong side, it has all the bracketry for coil springs which would have to be cut off. It also has a weak two-piece axle with vacuum disconnect that never worked correctly and would have to be fixed. It also has sealed unit-bearing hubs which are nearly impossible to convert to locking hubs (Warn made a kit once upon a time but it was over $1000). The rear axle of the XJ would be a Dana 35 and there is really not much good that can be said about them. I wouldn't even consider trying to put one under a CJ.
Just because the XJ axles are available to you doesn't make them a viable candidate for a swap. Narrow track AMC 20's are a dime a dozen, there are currently about 30 of them on Ebay and none of them is more than $300. Even to repair yours would probably be cheaper and easier than trying to swap. What do you mean by "blew it apart" exactly?
Pathkiller is offline
Wagoner/Cherokee Axles.. Exposed Jeep CJ Forum 8 02-04-2010 08:27 AM
Cherokee D44 axles in a CJ5??? 1FASTCJ Jeep CJ Forum 5 05-04-2009 08:51 AM
Swapping 79 Cherokee Axles into a 79 CJ7 Greyness Jeep CJ Forum 2 03-18-2009 06:42 AM
Stronger axles for a 1984 CJ7. Which ones? Frankcr Jeep CJ Forum 9 12-21-2006 12:52 PM
Cherokee Chief D44 Axles? Matt in TN Jeep CJ Forum 3 04-19-2006 04:53 AM
