1984 alternator question - JeepForum.com
post #1 of 4 Old 11-30-2011, 01:58 PM Thread Starter
wellmax
noticed today that the volt gauge was running at the top end of the green line. about 16 volts
turned on lights and it fell back to 12=14 volts.
the jeep had just been started and had not been started in about 1 week, so it could have been in a charging cycle.
should i have a worry or just drive it for awhile and keep my eye on the volt meter???
thanks,
wellmax is offline
post #2 of 4 Old 11-30-2011, 06:18 PM
Mike Romain
That can indicate a low battery just getting it's charge back up, but I find that when the gauge gets swingy, It is usually time to clean the ends of the battery cables. Don't forget the main cables have two ends eh, the other end is the one that bites you usually for a bad connection.
I also find if I polish up my fan belt the gauge can get swingy and kill the battery slowly. To test for that I take a cold off engine and see if I can hand slip the alternator pulley. If I can, it for sure won't hold under load and either needs tightening or replacing. A loose one usually makes noise, a polished one just slips. I killed 3+ belts a season when I used to mud run. Mud=liquid sandpaper.
Mike
Mike Romain is offline
post #3 of 4 Old 11-30-2011, 06:38 PM Thread Starter
wellmax
Thanks,
will check battery ends (both ends)
and check belt tension, may need a new belt as it has been on there for a good while.
Thanks again for the tips,
wellmax is offline
post #4 of 4 Old 11-30-2011, 06:40 PM
86cj74.2L
86cj74.2L's Avatar
U ever make the alternator water wheel gizmo?
86cj74.2L is offline
1984 Jeep CJ7 question.... ImBroken Jeep CJ Forum 11 09-28-2013 05:34 AM
1984 CJ7 question gary4569 Jeep CJ Forum 2 08-01-2011 04:32 PM
1984 CJ7 Vacuum Advance question gary4569 Jeep CJ Forum 8 04-24-2011 08:22 PM
1984 CJ-7 with Chevy 350 Temp Question kev12 Jeep CJ Forum 6 08-18-2010 07:37 PM
Simple Oil Pan question (CJ7-1984) machacker1 Jeep CJ Forum 5 01-02-2006 07:59 AM
