1983 Rear body mount bolt stripped - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1983 Rear body mount bolt stripped
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSOPTIC ARMOR WINDOWS all sale now !!!!!!!!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 12-20-2013, 11:58 AM   #1
couyon
1983 CJ7
I was replacing body bushings and think I stripped the bolt above the gas tank. Any suggestions on removing the bolt?
couyon is offline   Reply With Quote
Unread 12-20-2013, 12:36 PM   #2
Renegade82
Renegade82's Avatar
1982 CJ7
I assume your talking about the support arm mount / rubber body mount at the crossmember. Did you strip the bolt's head or is the bolt itself turning in the body mount in the bed support? Theres really no good way for access without dropping the gas tank. I would normally say to either apply some heat or to weld a nut to the bolts head, but I wouldn't recommend that with the tank right there and the possibility of gas vapors.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 12-20-2013, 01:30 PM   #3
couyon
1983 CJ7
The bolt spins. The head of the bolt is still good.
Unread 12-20-2013, 01:48 PM   #4
couyon
1983 CJ7
The bolt spins. Is the nut located in the channel?
Unread 12-20-2013, 03:47 PM   #5
Renegade82
Renegade82's Avatar
1982 CJ7
Yes, so theres really no access other than cutting in to it from the topside. It's just a large square nut. Theres some pictures of it in my build thread probably around page 5 or so. I don't have time at the moment to copy the pics to this thread or I would.
Unread 12-20-2013, 07:44 PM   #6
yahwhy
1982 CJ7
Which mount is it? if its one in the wheelwell I cut two slits where the channel is, the bent up the tab, then drilled out the spot welds that captures the nut, then got a long chisel and broke it loose, then fished it out.
Then welded a nut to a piece of 1/8 plate steel just a little smaller than the channel and fished it in to line up with hole, then beat the tap back down and welded it back up.
yahwhy is offline   Reply With Quote
Unread 12-21-2013, 07:32 AM   #7
couyon
1983 CJ7
It's the mount right above the gas tank on passenger side.
Unread 12-21-2013, 05:20 PM   #8
GB3440
Wife: you spent how much?
GB3440's Avatar
1979 CJ7
I had to do exactly what Yahwhy did on three mounts. Cut a flap in the sheet metal above the mount which will allow you access. Use a LOT of anti-sieze on all threads when you reassemble.
GB3440 is offline   Reply With Quote
Unread 12-22-2013, 07:05 AM   #9
couyon
1983 CJ7
Did you cut a hole on top behind the rear seat?
Unread 12-22-2013, 09:56 AM   #10
Renegade82
Renegade82's Avatar
1982 CJ7
I cut mine out from the bottom. Going from the top would be easier to do but heres what your up against.
