1983 CJ7 Rebuild - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1983 CJ7 Rebuild
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-28-2012, 08:24 AM   #106
Renegade82
Renegade82's Avatar
1982 CJ7
Sometimes it depends on the type of mount you have, as well as the body size of the shock. It takes some tweaking to find the right spot. Have someone inside turning the wheels on your command. Attach all the hardware but don't tighten it down. Watch for where it hits at. You may have to angle the shock slightly downward on the tie rod end so it misses the bulge of the cover. Do you have any pics that may help us see your setup? There are different mounts, axle tube or spring post (stock).
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 12-29-2012, 06:11 PM   #107
Crawlerkid
1983 CJ7
I'll post some pictures tomorrow of the setup. I read some articles online on how to set it up, but if i disconnect the steering stabilizer and swing it out of the way I get another 1/4 to 1/2 more turn.
Mojave heater (christmas present) is in! Finally have heat
Crawlerkid is offline   Reply With Quote Quick reply to this message
Unread 01-11-2013, 11:30 AM   #108
Crawlerkid
1983 CJ7
Pics of the heater. The om617 actually has an auxiliary coolant pump that circulates coolant through the heater, so I pulled that off the body and installed that. Calibrated the temp gauge with some resistors and an IR thermometer. Have 2500 miles on it so far and no problems to date.
image-2600210553.jpg   image-839715518.jpg   image-249654693.jpg   image-4189742634.jpg   image-3740636805.jpg
Unread 01-24-2013, 03:59 PM   #109
Crawlerkid
1983 CJ7
Turns out diesel gells at -8*F around here. Died 3 times and the last I couldn't restart. Got towed to school, sat in the sun and warmed up to around 3*F and it restarted. The anti gelling agent went in seconds later
What a day. I ended up getting a little frostbite on one of my fingers. But all better now.
Unread 01-28-2013, 12:05 PM   #110
Crawlerkid
1983 CJ7
Playin in sugar snow! I kept seeing these black lines in between my tracks and couldn't figure out what it was... until I looked back as I floored it and watched the coal roll
Unread 07-08-2013, 02:50 PM   #111
Crawlerkid
1983 CJ7
Jeep is off the road for college, it'll be a few years until it gets worked on again. Goal tire size is 35's on the stock amc20 and lp d30. I'll use those until something gives. Front end will be fiberglass, going with the correct lift springs up front to level it correctly (ditch the huge shackles.) OBA and a hydraulic winch are on the list, along with a snorkel and light bar. I had a jeep bud give me a junk hardtop that'll become a hard halftop, after I add to the current sportbar and get race buckets/5 pts. Lockers are on the list too.
Engine will stay stock, although I'l going to have the crank balanced, new rings, and do a timing chain while I'm in there.
Got 22-25MPG all the way up till I parked it (indoors.) LOVE the swap. Running doorless and topless, you could hear the turbo spool really audibly, and it really turned some heads.
Unread 11-24-2013, 08:57 PM   #112
NCjeepJoe
1: Nice rig and write up, very impressive for any age. 2: I've got a 77 CJ5 I'm trying to swap the 258 for the OM617 next year, so I'd love a "how to" write up. 3: Try to get some jeeping in! It's be a shame to let that beast sit for years!
NCjeepJoe is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 01:50 PM   #113
beersensations
Hey what did you do for the ignition? I want to bypass to make mine a keyless ignition but was wondering your route for shutdown since it is through the vacuum lines.
Cheers!
beersensations is offline   Reply With Quote Quick reply to this message
Unread 04-27-2014, 08:54 AM   #114
Crawlerkid
1983 CJ7
Sorry for the delay! I currently just pull vacuum on the shut off line. In the future I'm building a tractor style pull handle to pull vacuum on it and shut it off.
I'll be tearing the jeep apart for upgrades soon (suspension and gearing), and can do a "how to swap" if interested.
I'm looking for the following if anyone has these, PLEASE let me know! Ask everyone you know! I need to get back on the road
4" lift springs (or 4.5") front and rear
drop pitman arm
double cardan driveshaft
dana 30 lunchbox locker
carrier install kits for amc 20 and dana 30
tube fenders
Located in Charlevoix Mi, can paypal money
I also got a gopro (Hero 1 HD) and a suction cup mount so way better videos are in the future!
-Grant
Unread 04-27-2014, 06:25 PM   #115
Crawlerkid
1983 CJ7
Found springs, and pitman arm. Still looking for other parts!
Unread 05-06-2014, 08:30 PM   #116
Crawlerkid
1983 CJ7
4" lift springs are in, looks like my front driveshafts is maxed out :/ not interested in doing a t case drop. Are there any stock driveshafts off another rig that are a few inches longer than a stock cj shaft? I'll probably do a xj shady (shortened) in the rear
Thanks
Unread 03-04-2015, 04:39 AM   #117
Denzien
Denzien's Avatar
Denzien is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 10:02 PM   #118
Crawlerkid
1983 CJ7
Work has started again! Got the axles pulled out, 4.10's will start going in tomorrow, new clutch parts on the way, then it's time to do the body, wiring and hit the roads. Parts I'm looking for: Flat (tube) fenders, rear armor, rock sliders, extended drive shaft for the front, double cardan joint driveshaft for the rear, full cage, 16" wheels (5x5.5 pattern)
Progress pics:
My old 33's are for sale (wheels included.) Two of the tires are worn out, but the other 2 are probably 50%. Pro comp mud terrains
Unread 04-06-2015, 09:46 AM   #119
Crawlerkid
1983 CJ7
Started the regear, put everything together with the stock shims to get a starting point (in hopes that I lucked out) and got this pattern:
Unread 04-06-2015, 11:10 AM   #120
Crawlerkid
1983 CJ7
These are used gears btw
