1983 CJ7 Rebuild - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1983 CJ7 Rebuild
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 11-16-2012, 10:19 AM   #76
Crawlerkid
1983 CJ7
3.73's were a stock ratio in the CJ's right?
I could get them cheap used if so.
Crawlerkid is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 11:02 AM   #77
8pitcher
3.54 and 2.73 were stock.
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 11:15 AM   #78
Crawlerkid
1983 CJ7
Dangit
Well I may go with 4.10's since I'm going to wheel it and potentially run bigger tires. By the time I buy one piece axles, new gears and carriers, would it be cheaper to go to an 8.8?
Unread 11-16-2012, 01:29 PM   #79
Renegade82
1982 CJ7
Actually, it depends on the year and engine as to what was stock for that year.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 04:18 PM   #80
inovermyhead2
1983 CJ7
Originally Posted by matt1981cj7
crawler,
if you're building an economical dd, that will be more than capable off-road. I think the 3.73s will suit you better. 4.10s will wind pretty tight at highway speeds with a 4-speed.
On the other hand, if want a crawler, that will pop a wheelie off the line, but will be howling at 65 mph, then go with the 4.10s.
Matt
x2
[url]http://www.jeepforum.com/forum/f8/83-cj7-finally-complete-finished-pics-1429955/[/url]
[url]http://www.jeepforum.com/forum/f8/just-another-83-cj7-build-thread-1325757/[/url]
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Confer Engineering Shackles
32x11.50x15 BFG All Terrains
[QUOTE]whoever invented Torx bolts should be shot in the face, burned then pissed on - saskcj7[/QUOTE]
inovermyhead2 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 04:32 PM   #81
Crawlerkid
1983 CJ7
The more I'm reading suggests 3.73's as well.
I'll go with those. I want to get good mpg. Did 3.73's come in any CJ's or wranglers that I could buy the pinion ring and carrier as a stock take out part?
Unread 11-16-2012, 04:45 PM   #82
inovermyhead2
1983 CJ7
Wranglers won't work. No Cj's that I'm aware of. The ring and pinions are not expensive, it's the installation if you are not qualified or don't own the proper tools. You will also need a different carrier for your AMC 20 going from 2.73's
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Unread 11-16-2012, 06:10 PM   #83
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
The D30 carrier from any wrangler/cherokee/comanche etc. will fit just fine in a CJ D30 case....the gears however will not if they're from a HPD30 (which I think only came in the YJ, XJ & MJ....TJ's and ZJ's would work) . Disclaimer, the previous gear info is from the interweb so who knows how accurate it is.
And yes, CJ's came with 3.73's but they seem to be more common in the NT equipped Jeeps with an auto tranny.
Originally Posted by Crawlerkid View Post
........ I want to get good mpg........
MPG in a CJ?.........
Sorry, I couldnt resist
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is online now   Reply With Quote Quick reply to this message
Unread 11-16-2012, 06:33 PM   #84
inovermyhead2
1983 CJ7
[QUOTE=jeepwhore;14467193]The D30 carrier from any wrangler/cherokee/comanche etc. will fit just fine in a CJ D30 case....the gears however will not if they're from a HPD30 (which I think only came in the YJ, XJ & MJ....TJ's and ZJ's would work) . Disclaimer, the previous gear info is from the interweb so who knows how accurate it is.
I thought I was pretty specific about referencing changing the carrier for the AMC 20 NOT the D30. The 20 obviously was never available in a Wrangler. And as far as the gearset for the D30 is concerned, you just confirmed they will not work from a Wrangler. So that being said, safe to say, Wrangler is not a candidate for a donor. And BTW, there are a lot of cj diesel swaps running around getting 25-27 mpg if they are set up correctly.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Unread 11-16-2012, 07:04 PM   #85
Crawlerkid
1983 CJ7
Good as in good for a jeep haha. I'm shooting for 18-20mpg
Good to know. I'm on a budget, so I was seeing if anything came stock with those #'s
Thanks!
Tomorrow I'll be making some caster shims for the front axle!
Unread 11-16-2012, 07:43 PM   #86
inovermyhead2
1983 CJ7
Thanks!
If I were you and I am assuming you have another vehicle you can use. Forget about the caster shims. Park that CJ until you can put some proper springs in it. Those shackles are DANGEROUS. They can and will bend sideways and potentially roll you over! I know it's exciting that you have it running and driving now, but it's time to use your head for safety. You have proven you are very intelligent just by the fact that you pulled off this swap at such a young age. Now it's time to switch gears and think about Safety. Save up for a 2 1/2" lift. Rough country gets a bad rap because of it's harsh ride but with the weight of the diesel, I don't think it will be an issue. They are fairly inexpensive lifts. I have a Rancho 2 1/2" lift and with the weight of my SBC, it rides awesome. Slightly more money, but I highly recommend it.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Unread 11-16-2012, 07:56 PM   #87
jeepwhore
jeepwhore's Avatar
Not sure what your point is here. As you bring up, the M20 didn't come in a wrangler so I didn't mention it....but if the rear gets changed so does the front (unless he was staying between 2.73 & 3.55). 3.73 and higher numerically requires a new carrier. I was just commenting on your response to answering the OP's questions about possible parts donors. A wrangler may not be a gear set candidate but if on a budget, the carrier from a YJ/XJ/MJ/ZJ will work in a CJ D30.
As for the MPG comment, it was tongue in cheek......I figured all the smilies were kind of a give away.
:-D
Unread 11-16-2012, 08:08 PM   #88
inovermyhead2
1983 CJ7
Gotcha
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Unread 11-16-2012, 08:17 PM   #89
Crawlerkid
1983 CJ7
No I knew what ya meant no problems there
Unfortunately the Cj is the only means of transportation for me at the moment, so I'll have to keep it on the road. I'll ask a few of my buddies if they know of someone with some springs so I'm not trying to bandaid it to death with shims and huge shackles. Trust me, it's a handful to drive! I'm able to live with the ratios for now, I'm slipping the clutch more than usual, but this spring it's getting a new one anyways.
More to come!
Unread 11-16-2012, 09:14 PM   #90
jeepwhore
jeepwhore's Avatar
I may have missed it, but what was the need for the walrus tusk shackles? Was it just to level the jeep? If so, I'd sacrifice aesthetics for safety and put stock shackle on the front. It'll look ridiculous but you know you won't end up on your lid.
If it was for tire clearance, well, not much you can do then.....
Hutch1200 has some 2.5" springs......free.......he's in PA but maybe you can figure something out.
:-D
