1983 CJ7 Rebuild - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1983 CJ7 Rebuild
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 06-11-2012, 11:39 PM   #1
Crawlerkid
1983 CJ7
1983 CJ7 Rebuild
Hey all, new here, and new to the 4x4 scene. I'm 17 and have been a mechanical minded person from they day I helped my dad wrench on our own cars and bikes. I've owned multiple dirtbikes, 4 wheelers, snowmobiles, ect, and recently bought a 99 Kia Sportage, which I lifted 3.5" (suspension) and ran 31"s on. It was a fun rig, but I wanted something different. Before I was even born my dad purchased my 1983 CJ7 from a cousin that had blown the 4 speed tranny in it. The rig had 60,000 miles at the time. My dad bought headers, a Holley 4 brl and an offenhouser intake for the I6. Both axles have been totally rebuilt, warn hubs, new leafs, stripped and primed frame, and a fiberglass tub were purchased. There literally are shelves of the CJ parts haha. Since it wasn't "my" project, I never was into rebuilding it, so it's sat for a total of about 20 years... until now. I recently had the opportunity to drive a 2002 wrangler with the top and doors off (on 33 Mickey thomsons) and literally fell in love with the jeeps right then and there. Something about looking down and serif the road fly by and watching those tires rolling down the road totally clicked with me.
So, crazy long intro aside, here's where I'm at. I really want a diesel in this jeep, but want to keep the stock axles, t case, and if possible the tranny. Cost wise I was thinking a 6.2? Don't flame me, I know there's a million better choices out there, but I'm on a TIGHT budget, and can't afford a 4bt. The jeep is going to see 90% road use and the rest is open fire roads.
The tub is just sitting on the frame, and still needs to be mounted, and all the holes cut, where can I get a template?
Should I do a diesel swap now, since the frame is just a roller, or put the I6 in and swap later?
Thanks all, and what a great forum!
-Grant
Crawlerkid is offline   Reply With Quote Quick reply to this message
Unread 06-12-2012, 12:27 AM   #2
benullman
1981 CJ7
I6 now. Its got plenty of power and not enough credit.
ill be watching. got my 81' at 16 and it was a blast!
Ben
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 06-12-2012, 02:45 PM   #3
Crawlerkid
1983 CJ7
I'm dropping the I6 in now, what side should each engine mount go? There's one with a wide spaced 4 holes (this one is longer also) and one that has closer spaced 4 holes (this one is shorter.)
I've attached a pic of what I currently have the engine setup like. Is that the correct mount for the drivers side?
Unread 06-13-2012, 11:29 PM   #4
Crawlerkid
1983 CJ7
Well I had it backwards (as always in my never ending luck.)
May as well post some pics of the jeep right?
Unread 06-13-2012, 11:53 PM   #5
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Looks like that started life as a Laredo. When I got my '85 Laredo the place I got it had a few Jeeps. The only ones that caught my eye were the '83 black Laredo and '85 black Laredo. I liked the stripes on the '85 better and it was in a little better shape so that's what I ended up with.
Looks like you've got everything you need to get this done. Just don't lose focus and you'll have a nice rig someday. Once you get the Jeep bug it's hard to shake.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 12:04 AM   #6
Crawlerkid
1983 CJ7
I'll most likely be painting the fenders white to match the body. I have a harbor freight gun, and it actually lays paint really well.
I want to go all white body, black fender flares, wheel spacers (1.5") black rims and black accents. It would look good I think
Unread 06-14-2012, 12:13 AM   #7
Crawlerkid
1983 CJ7
Like this:
Unread 06-27-2012, 09:32 PM   #8
Crawlerkid
1983 CJ7
A little update:
Inherculined the entire frame, have got the tranny and skid plate in, the hood is now on and the body is mounted on 2" spacers.
Could someone make me a template for cutting out the firewall? Or have a spare firewall the could send me? I'd be willing to pay you
Unread 06-27-2012, 09:38 PM   #9
8pitcher
i have a firewall from a 1982 cj7 it is steel and has some rust but the firewall is overall in pretty good shape
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 09:51 PM   #10
Crawlerkid
1983 CJ7
Would you make a template of it?
Unread 07-14-2012, 01:21 AM   #11
Crawlerkid
1983 CJ7
A little update:
The body is bolted down, the tank is in, the dash is in, interior wiring in, doors on, intake and exhaust on, firewall cut for all accessories. It took a lot of work.
Unread 07-17-2012, 12:05 AM   #12
8pitcher
Enjoying your build.
Unread 07-17-2012, 05:56 PM   #13
TJs83CJ7
Is that the stock windshield or did you put in a fiberglass frame? I am having trouble with my windshield.
TJs83CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 03:22 PM   #14
Crawlerkid
1983 CJ7
Stock windshield. It''ll eventually be fiberglass (as will the front clip.)
I did the nutter bypass (removed sooooo much wiring) and got it running
Unread 07-23-2012, 04:00 PM   #15
1SASjeepster
Crawlerkid,
Great job! I can't wait to see it finished.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline   Reply With Quote Quick reply to this message
