1983 CJ7 Project - JeepForum.com
post #1 of 23 Old 03-24-2013, 01:52 PM Thread Starter
Stormpaw
1983 CJ7
1983 CJ7 Project
I have been lurking about the forum here for years, and thought it was about time I tried to contribute. I figured I would share the things I have been working on. Keep in mind I am no expert, but maybe someone can learn from my mistakes.
Firsts the basics: The Jeep is a 1983 CJ7. The drive train consists of a 1978 Chevy 350 engine, 1972 SM465 transmission, Dana300 transfer case, Dana30 front axle and a AMC20 rear axle. My overall goal it to keep the Jeep street worthy while restoring it to a somewhat original appearance and improving performance whenever possible. It may see some difficult terrain from time to time, but but mostly it is a daily driver.
I bought the Jeep back in 2010. After a little maintenance (and a transmission swap), we went for a quick drive drive (4500 miles) up the Alcan highway and a four day ferry ride to my island home (in Alaska).
When I bought the Jeep the T5 was pretending to be a T4 (overdrive was shot) so I bought and rebuilt a SM465 and an adapter (from Novak.) After a lot of cursing and more than a little blood it fit right in.
Oddly enough the Jeep was still geared a little high with the 3.31:1 axle gear ratio (soon to be changed.) No wonder the overdrive went out. Other than the fact that it was a T5 behind a Chevy 350 (as if that wasn't enough) in overdrive (.86) at 2500 RPM with 32" tires it should have be going around 85mph according to my calculations. In other words way to high.
Here you can see my hack job to make the SM465 fit.
A couple years later, you can see why that was a bad idea.
Note the big crack next to the mount bolts.
More to come....
Stormpaw is offline
post #2 of 23 Old 03-24-2013, 04:07 PM Thread Starter
Stormpaw
1983 CJ7
So after a bit of searching around I realized my only option since I can't weld (no welder) was to have a new bracket made. I took some measurements and contacted the gentlemen at Throttle Down Kustoms, who sell custom brackets made to fit a Jeep.
A few weeks later I had this monster.
Here it is getting primed and painted.
...and there goes the paint....
After a bit of work and some cursing I realized I had given the guys at TDK incorrect measurements. The old bracket had become so weak it was sagging over an inch at the mount. Great. As a temporary fix I went and bought a stack of washer to take up the gap. I also had to pry the transmission toward the drivers side about a half inch. I am not exactly sure why. Either way I had to loosen the transmission shifter plate to leave enough room. I will have to re-cut the holes, but It seems to be a much better position overall and will prevent the dual T-case shifters I installed when I swapped the transmissions from rubbing on the tub.
Yep, it doesn't fit, but the washers seem to be working for now.
The shifter plate will need the holes enlarged before in can be screwed back down.
Oh I also tried drilling out one of the broken bolts.
I managed to get it out with an extraction tool, but damaged the threads... so much for that. Maybe, I will re-tap it later.
More later....
Stormpaw is offline
post #3 of 23 Old 03-24-2013, 04:33 PM
skizriz
1978 CJ7
Some day, somewhere, somehow, every thing will go right.
If you are one of those people who goes off the hook and starts throwing tools, you have no business owning a CJ. Working on them is a lesson in patience.
Nice job or recovering on the fly. I had a similar problem when I made a cardboard template of my belly pan to transfer on to my replacement frame. Only one of six bolts lined up when I went to install it.
skizriz is offline
post #4 of 23 Old 03-24-2013, 06:33 PM Thread Starter
Stormpaw
1983 CJ7
Heh, yes. Patience is not an option. It is mandatory.
Stormpaw is offline
post #5 of 23 Old 03-26-2013, 07:15 PM Thread Starter
Stormpaw
1983 CJ7
Next up: The Wiring Harness (or How has this thing not burned to the ground?)
Last fall I started looking into ways to improve the brightness of the Jeep's headlights. I had already replaced the old sealed beams with H2s. They were better, but not as bright as I was hoping for. After a bit of searching I ran into Jeephammer's great write up on headlight upgrades.
Extremely impressed, I proceeded to read every post I could find about wiring by Jeephammer including his posts on dedicated grounds, basic wiring, and alternator wiring.
It was about this point when I, once again, realized the PO who installed the engine had no idea what he was doing (the engine is also poorly placed causing the distributor to rub the firewall.)
Circuit protection? I don't need no... wait... yes... yes I do....
So the headlight project is now on a back burner (though I already have the relays). Instead, I am giving the wiring harness I complete overhaul and upgrade including dedicated grounds.
Laying the ground work (buss bars from VTE.)
Also note the hand drill.... Yep, I am to cheap to buy an electric drill....
The ground buss bar may not be in a very good place, but I think it will work.
Dash ground buss bar... and a horrible mess of wires that will be getting cleaned up in the process.
More later....
Stormpaw is offline
post #6 of 23 Old 04-25-2013, 10:20 PM
brian613
1977 CJ5
looks good man i had to "trim" my skid so my np435 would fit. i didnt have to trim nearly as much as you did though..
as far as wiring i bought a kit from EZ wiring and couldnt be happier with it. the wires are labeled every few inches and are correct size or larger for the load demand. i did have to put my own ends on but it came with headlight and ignition modual connectors but for the price difference for a painless i can put my own ends on..lol
77 cj5 304 v8 np435 twin sticked dana 20 transfer scout dana 44's with 4.88 gears
brian613 is offline
post #7 of 23 Old 09-09-2013, 12:18 PM Thread Starter
Stormpaw
1983 CJ7
If anyone ever wondered what happened to me, here is a (sort of) quick update.
Back in September of 2012, after coming down out of the mountains low on oil (my filter had sprung a leak), I stopped at a stop sign and heard a strange sound. I dropped it into first gear and... nothing happened. I looked under the Jeep, but everything seemed fine. I then tried four wheel drive. The jeep took off no problem... for about 100'. Then the back end started making a horrible noise and felt like the wheel had fallen off. In fact, the wheel was still there, but it was sticking out about a foot further than is should have been. The rear passenger side axle shaft (and wheel) were coming out.
I had it towed to a near by shop. After an aggravating 3 months of waiting and one failed attempt at the repair I paid the (rather high) bill and drove it home. I replaced the oil filter, and noticed the axle seal was leaking. I took it back and was told they had put the seals in backwards. They took it back and after another month they were done. I was very happy to have my only means of transportation back.
About a year later in December, and after probably less than 200 miles (I live on a small island) the axle shaft once again came out while I was driving to the post office in a gale. This time I had it towed to a different shop. I no longer trusted the first shop and didn't want to wait another 4 months. I discussed it with the head mechanic and decided to have the axle gears changed this time while it was apart. He told me it had been put together wrong and that he was surprised it hadn't fail sooner. However, while the CJ7 was at the shop it managed to get knocked off of the jack stands it had been left sitting on while they worked on the axle (by a customer). I was off the island at the time, but had to deal with the insurance company even though I hadn't seen the accident or the damage.
In the end the insurance company said there was no damage. When I got back I found the gas tank skid plate dented in, the welds that hold the bumper on broken and the tire carrier cracked. However, the case had already been closed.
After 6 months I finally got the jeep back. The only problem was (aside from the many others I mentioned) they had only worked on the rear axle. So it had different gear ratios in the front and rear. The head mechanic had quit, and the others didn't seem to realize what was going on. The man who had left decided to go into business for himself, and offered to finish it for me at his home. He had done an excellent job with the rear axle and was a nice guy so I agreed. So a week later I left the jeep in his care once again. After another month I left the island again (I travel a lot) hoping it would be finished when I returned.
If you haven't guessed by now... no... no, it wasn't finished. He hadn't even started. His neighbors had complained to the town that he was running a business out of his home and forced him to stop. He is still working on getting that straightened out. So after 10 months I finally have my Jeep back. It may have different axle gear ratios in the front and rear, but at least I have it....
That's all for now....
Stormpaw is offline
post #8 of 23 Old 09-10-2014, 05:05 PM Thread Starter
Stormpaw
1983 CJ7
My CJ7 has finally returned! I've only had it off and on for about a month or two since my last post (a year ago). It sat around waiting for front axle work the rest of the time.
The front axle has finally been completely rebuilt, new ball joints, u-joints, bearings, seals, hubs, and 3.73 gears to match the rear. Both axles are now as good as new. The rear drive shaft was cut to a proper size. I knew it was too long (thanks to a PO), but didn't realize it had been binding. I had planned to replace it, but I will save that until I have a chance to get the new engine mounts installed. Also, while the axle was out anyway, I got the new Old Man Emu YJ springs and shocks put it, that I've had sitting about since before the rear axle went out. I still need to check the caster angle and rear driveline angles because we had some miscommunication on the shims, but overall I am very pleased.
I should be posting more soon.
On the road again! Oops, ran out of road....
My CJ7 and I are partners. I do my best to keep it running and it does its best to get me were I am going. Unfortunately, we both sometimes fail....
Stormpaw is offline
post #9 of 23 Old 09-10-2014, 10:30 PM
CrankyD
1983 CJ7
Cool! keep the tales coming, glad it's running!
CrankyD is offline
post #10 of 23 Old 09-11-2014, 11:41 AM Thread Starter
Stormpaw
1983 CJ7
Thanks! I am really excited to be driving and working on it again.
I will be on a business trip for the next few weeks, but I already have quite a few more pictures to post.
Stormpaw is offline
post #11 of 23 Old 09-11-2014, 12:15 PM
Renegade82
1982 CJ7
Man! As if life wasn't complicated enough living on an island.... in Alaska .... then to have a Jeep as your only wheels. My hat's off to you. Interesting stories.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #12 of 23 Old 09-11-2014, 02:50 PM
stokey04964
1980 CJ7
Which wiring harness did you use? Does the harness come with the Headlight upgrade and relays? Thanks
stokey04964 is offline
post #13 of 23 Old 09-11-2014, 04:53 PM Thread Starter
Stormpaw
1983 CJ7
Renegade,
Yeah, it has been... interesting, but I can't imagine ever trading it for anything. I'll never forget driving it up to Alaska from Missouri, just me, the Jeep, and 4500 miles of open road (and a whole lot of gas stations).
Stokey,
I have been making the wiring harness myself. It isn't that difficult and was cheaper even with the tools I bought for the job. It has taken some time, but I believe the quality is as good, or better than anything you can buy. I should be posting more about what I did in the next week or so, if you are interested.
Stormpaw is offline
post #14 of 23 Old 09-11-2014, 07:55 PM
stokey04964
1980 CJ7
I subscribed to this so i will look out for it. About to start mine and will need to address some wiring and the light upgrade.
post #15 of 23 Old 09-12-2014, 01:50 PM
Splinter
1980 CJ5
I'm in !!
Splinter is offline
