1983 CJ7 coolant overflow/recovery bottle - JeepForum.com
post #1 of 17 Old 08-02-2010, 07:13 PM Thread Starter
cjkcj7
1983 CJ7
I have a 1983 CJ7 with a 258.
I did a search on JF regarding the coolant overflow/recovery system. I understand that the radiator is pressurized, but the overflow/recovery bottle is not. Is this correct?
The reason that I ask is that I need a new cap for my overflow/recovery bottle. Should this cap be vented? From what I can tell, it shouldn't be, but I wanted to double check.
Thanks in advance for the help.
cjkcj7 is offline
post #2 of 17 Old 08-02-2010, 07:44 PM
143hc
The spring in the cap keeps the rad pressurized. When the coolant gets hot it expands and pushes up the spring in the cap and runs out to the overflow, then is drawn back in when the coolant cools off and the spring returns to normal. So the rad is pressurized but the overflow isn't and doesn't need venting. But the tube has to run to the bottom of the overflow so air doesn't get sucked in.
Now, 84 CJ7 Laredo , weber 38, 3.73's, Alloy 1pc., AuburnGears LS, hei/tfi, 2.5" BDS, Perf. Access. Years ago, 81 CJ7 304, 33's
143hc is offline
post #3 of 17 Old 08-03-2010, 06:19 AM Thread Starter
cjkcj7
1983 CJ7
That's what I figured. Thanks.
cjkcj7 is offline
post #4 of 17 Old 12-22-2014, 09:32 PM
vsanzbajo
The overflow bottle cap is really loose. It does not really close properly. It is extremely easy to open. It seems like it could just open alone. Is that normal?
Thanks
vsanzbajo is offline
post #5 of 17 Old 12-23-2014, 04:35 AM
Mike Romain
Thanks
Yes it is normal. The cap is just to keep dirt out.
Mike
Mike Romain is offline
post #6 of 17 Old 12-23-2014, 04:56 AM
RedNeckCorvette
1979 CJ7
I replaced the one on my F-250 with a metal juice cap over twenty five years ago and it is still going strong.
RN
RedNeckCorvette is offline
post #7 of 17 Old 12-23-2014, 05:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My '81 never came with an overflow tank and has never needed one.
I don't think how tight the cap fits matters at all.
Matt
Matt1981CJ7 is offline
post #8 of 17 Old 12-23-2014, 05:37 AM
keith460
Jeep. There's Only One
keith460's Avatar
A lot of CJ's did not come with the Overflow Tank which is included with the HD cooling system. Mine doesn't either and never needed it. But the Overflow tank has venting either via a hole or the cap or loose cap. When coolant is being pushed into the tank, air in the tank must be displaced or vented. When coolant is being sucked back into the radiator, air needs to be reintroduced back in the Overflow Tank by some means of venting. If it was air tight, coolant being pushed into the tank would try to expand the tank or collapse it when coolant is being pulled back to the radiator.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 17 Old 12-23-2014, 08:34 AM
CSP
Mine didn't come with an overflow, but I added one after seeing coolant dripping out of the overflow tube on several occasions. Wheeling in Moab in June when it's 105 tends to push the cooling system a bit.
CSP is offline
post #10 of 17 Old 12-23-2014, 08:44 AM
j33pman
I added a generic overflow tank to mine when I did my rebuild last year. I never had a factory one.
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #11 of 17 Old 12-23-2014, 11:01 AM
RedNeckCorvette
1979 CJ7
My 1979 has a, utility discharge gravity to ground based drainage system. Very technical.
RN
post #12 of 17 Old 12-24-2014, 03:34 AM
dg6772
I didn't have one either, I used a washer fluid bottle. Been working fine for 2 years. I bolted it low on the fender in front of battery tray.
Dave in Muskegon using JeepForum app
dg6772 is offline
post #13 of 17 Old 12-24-2014, 06:03 AM
RedNeckCorvette
1979 CJ7
looks like you have given me another thing to to consider. I will be on the look out for the right container. I know we have a several OEM wind shield wash containers around here some place. Just might be the ticket.
RN
post #14 of 17 Old 12-24-2014, 06:07 AM
ADDZ71
1979 CJ7
The overflow bottle should not be mounted low. Preferably the two fluid levels should remain about even or higher for the overflow if possible (relative to the ground). When the cap opens you want flow to be in either direction but favoring the radiator.
ADDZ71 is offline
post #15 of 17 Old 12-24-2014, 06:11 AM
dg6772
ADDZ71 is correct, but the holes were there and at the time I was looking for a stock one. I will be moving mine to a better location. Someday.
dg6772 is offline
Cooland Overflow Bottle - 84 CJ7 Hibbitz Jeep CJ Forum 9 05-01-2013 08:28 AM
Radiator overflow bottle with loose cap... JUNK726 Jeep CJ Forum 1 04-19-2010 06:34 PM
Stock locations of washer bottle and overflow bottle? cw4stein Jeep CJ Forum 3 12-23-2009 08:46 PM
radiator overflow bottle, 80 cj7? stumpman Jeep CJ Forum 7 06-12-2008 11:16 AM
overflow bottle CJMONEYPIT Jeep CJ Forum 5 01-10-2003 06:38 PM
