1983 CJ 7 Drive Belt Diagram and Alternator Install - Page 2 - JeepForum.com
post #16 of 20 Old 06-10-2013, 07:27 PM
yellow85cj
Here's a routing from an 82. Looks like it has the idler pulley. Did you have a 3rd pulley bolted to the crank pulley? This set up needs one.
Currently in pieces - all of them
yellow85cj is online now
post #17 of 20 Old 06-10-2013, 09:19 PM
yellow85cj
Here's a compressor mount that looks like what you have. Part #2 looks like one of the brackets in your pics. Part 21 as well.
post #18 of 20 Old 06-10-2013, 09:27 PM
yellow85cj
And the pic of the alt mount that might go with the compressor mount. Any parts laying around that look like them?
post #19 of 20 Old 12-31-2013, 06:17 PM Thread Starter
Kcasler
1983 CJ7
Found it Thanks Yellow 85CJ!
Kcasler is offline
post #20 of 20 Old 01-01-2014, 06:21 AM
GlennLever
GlennLever's Avatar
A little late sorry
A-General
http://www.civilianjeep.info/84-86FSM/A-General.pdf
3,356KB file
Ba Engines General
http://www.civilianjeep.info/84-86FS...es_General.pdf
7,087KB file
Bb 150 CID 4 Cylinder Engine
http://www.civilianjeep.info/84-86FS...4_Cylinder.pdf
10,328KB file
Bc 258 CID I-6 Cylinder Engine
http://www.civilianjeep.info/84-86FS...6_Cylinder.pdf
10,530KB file
Bd Cooling & Fuel Systems
http://www.civilianjeep.info/84-86FS...el_Systems.pdf
13,924KB file
BE EGR, PVC & TAC Systems.
http://www.civilianjeep.info/84-86FS...AC_Systems.pdf
2,515KB file
Bf Fuel, Feedback & Exhaust Systems
http://www.civilianjeep.info/84-86FS...st_Systems.pdf
12.7KB file
Ca Electrical Systems
http://www.civilianjeep.info/84-86FS...al_Systems.pdf
16,159KB file
Cb Electrical Schematics
http://www.civilianjeep.info/84-86FS...Schematics.pdf
12,270KB file
D Clutch
http://www.civilianjeep.info/84-86FSM/D-Clutch.pdf
5,144KB file
E Gearboxes & Transfer Cases
http://www.civilianjeep.info/84-86FS...nsfer_Case.pdf
8,670KB file
F Automatic Transmissions
http://www.civilianjeep.info/84-86FS...ansmission.pdf
7,742KB file
Ga Steering
http://www.civilianjeep.info/84-86FSM/Ga-Steering.pdf
13,174KB file
Gb Steering, Front Axle
http://www.civilianjeep.info/84-86FS...Front_Axle.pdf
15,315KB file
H Rear Axle
http://www.civilianjeep.info/84-86FSM/H-Rear_Axle.pdf
9,086KB file
J Suspension
http://www.civilianjeep.info/84-86FSM/J-Suspension.pdf
4,763KB file
K Brake System
http://www.civilianjeep.info/84-86FS...ake_System.pdf
7,655KB file
L Heating/Air Conditioning
http://www.civilianjeep.info/84-86FS...onditoning.pdf
8,060KB file
M Accessories
http://www.civilianjeep.info/84-86FSM/M-Accessories.pdf
3,350KB file
N I.S. Notes
http://www.civilianjeep.info/84-86FSM/N-I.S._Notes.pdf
4,369KB file
O Auto Transmission Overhaul
http://www.civilianjeep.info/84-86FS...nsmissions.pdf
14,491KB file
P T-4 & T-5 Transmission Overhaul
9,372Kb / 9.15MB file
Q 4.0L & 4.2L(258 CID) Engine Overhaul
http://www.civilianjeep.info/84-86FS...4.2_Engine.pdf
10,201KB file
R '81 to '86 Jeep Parts Manual
http://www.civilianjeep.info/84-86FS...nual_81-86.pdf
37,223KB file
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
