1983 CJ 7 Drive Belt Diagram and Alternator Install - JeepForum.com
post #1 of 20 Old 06-08-2013, 03:17 PM Thread Starter
Kcasler
1983 CJ7
I need the drive belt diagram and Alternator mounting diagram for a 1983 Jeep CJ 7 with AC.
Kcasler is offline
post #2 of 20 Old 06-08-2013, 05:38 PM
LumpyGrits
Know'n the eng. might help some.
LG
LumpyGrits is offline
post #3 of 20 Old 06-08-2013, 06:08 PM Thread Starter
Kcasler
1983 CJ7
I have the 258 straight 6, stripped everything off during the rebuild, reviewed the Chiltons and Haines, but want to be sure I have it right...
Kcasler is offline
post #4 of 20 Old 06-08-2013, 06:10 PM Thread Starter
Kcasler
1983 CJ7
Factory Air and Power Steering. Installed a Clifford Stage 2 kit, Clifford Intake and Headers and DGAS 38 weber...
Kcasler is offline
post #5 of 20 Old 06-08-2013, 06:10 PM Thread Starter
Kcasler
1983 CJ7
Has 3 belts, no serpentine.
Kcasler is offline
post #6 of 20 Old 06-08-2013, 06:51 PM
LumpyGrits
You need to download a copy of the FSM
Those 2 manuals didn't have any pictures?
LG
post #7 of 20 Old 06-09-2013, 12:42 PM Thread Starter
Kcasler
1983 CJ7
Thx LG; First of all I am not a great mechanic, just a mad scientist who likes to tinker.
No pics in the nanuals that show the bracket setup. Problem is I took this apart about 2 years ago, and lost the photos I had during dismantle.
I have attached some pics and have a few questions if you can help...much appreciated...
Photo 125458 Small rectanglular palte has bend and "F" on one site- IS this the idler Adjusting bracjet plate? I have two, one is bent...
Photo 125539 Another view of the bent plate showing the "F"
Photo 125631 Triangular plate and angle iron bracket- Are these power steering related?
Photo 125749 alternator below AC bracket
Photo 125757 another view of above
Photo 125809 view of idler adjusting bracket and pulley
Photo 125836 Does center port go to PCV valve on valve cover?
Photo 125849 View of top of motor
Photo 1259908 View of passenger side of motor
Comments on these are much appreciated!
20130609_125458.jpg   20130609_125539.jpg   20130609_125631.jpg   20130609_125749.jpg   20130609_125757.jpg
20130609_125809.jpg   20130609_125836.jpg   20130609_125849.jpg   20130609_125908.jpg
Kcasler is offline
post #8 of 20 Old 06-09-2013, 02:52 PM
yellow85cj
58 and 39 go from alt to compressor. Look at 243's AC install and you will see. Looks like his is a bit different, still, the 2 brackets go from comp to alt. http://www.jeepforum.com/forum/f8/da...l#post13972535
31 triangle bracket is PS think the other bracket is AC/Alt related but not sure.
These are PS brackets for 84-86 should be all you need unless you have smog pump to re install (TX shouldn't need it as it is emissions exempt, just safety inspection)
Pretty sure you can get rid of the idler pulley on the drivers side if not using the smog pump.
Belts should run PS - water pump - crank. AC - water pump - crank.
Alt - AC.
Currently in pieces - all of them
yellow85cj is offline
post #9 of 20 Old 06-09-2013, 06:08 PM
Bubba Ray
On my 84 258 the alt is on top of ac compressor.
Bubba Ray is offline
post #10 of 20 Old 06-10-2013, 03:04 AM
BagusJeep
1981 CJ7
This may be teh correct diagram but you need to verify whether it is factory or not AC.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #11 of 20 Old 06-10-2013, 03:26 PM Thread Starter
Kcasler
1983 CJ7
Thanks for the input... Attached are some diagrams, but still none show the alternator setup below the AC... all are above the AC. The jeep was manufactured in Canada...
Also are pics of the two rectangular spacers- one has an F stamped on it, the other is slightly larger but has nothing stamped on it. I believe the F stands for front...please advise if you can.
I have the AC bracket and compressor mounted, and power steering brackets and drive pulleys ready to go.
Power Steering Pump Diagram.jpg   20130609_125458.jpg   20130609_130351.jpg   20130609_125757.jpg
Kcasler is offline
post #12 of 20 Old 06-10-2013, 03:36 PM Thread Starter
Kcasler
1983 CJ7
SP; The ac is factory, has a cast aluminum bracket with 3 bolts in triangular fashion. AC is mounted on top...need to confirm Alternator bracketing. I have two bolt holes: one large on top and a small adjustment screw on bottom that connects to the tensionier bracket.
Kcasler is offline
post #13 of 20 Old 06-10-2013, 03:45 PM Thread Starter
Kcasler
1983 CJ7
LG
Downloaded a FSM yesterday and it did not have diagrams than Chiltons or haynes...they gladly refunded the $$$
It is Factory air, made in Canada with the AC on top...see pics.
Has one aluminum AC bracket that bolts right to the block. Alt has two bolts I can see: one large on top and tensioning screw at bottom...seems real flimsy...
Kcasler is offline
post #14 of 20 Old 06-10-2013, 03:45 PM Thread Starter
Kcasler
1983 CJ7
No pics in either of my manuals
Kcasler is offline
post #15 of 20 Old 06-10-2013, 03:59 PM
texasdave
texasdave's Avatar
1980 CJ7
Go to Tom Ol jeep Collins web sight it has the parts manual which will show diagrams.
texasdave is online now
