1982 cj7 - speedo - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1982 cj7 - speedo
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 04-11-2015, 07:28 PM   #1
rtruesdale
1982 CJ7
1982 cj7 - speedo
Anyone have issues with the speedo needle swinging wildly across the gauge as you drive? can't figure out how to make is read "steady".
make sense?
Just working the little things out on this jeep. everything else fairly "tight"
rtruesdale is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 07:37 PM   #2
dmoore_64
1974 CJ5
Try to lubricate the spedo cable, or else it is internal to the speedometer and you will have to disassemble it to lube inside.
dmoore_64 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 03:40 AM   #3
RedNeckCorvette
1979 CJ7
If it is not in the cable and if you ever have your speedo out, remove the needle and put a small drop of grease on the pivot point of the needle.
RN
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
