1982 CJ Ignition - JeepForum.com
post #1 of 11 Old 03-03-2013, 02:08 PM Thread Starter
hiljak
1982 CJ7
1982 CJ Ignition
I have a problem with my 1982 key ignition. I have broken the pot-metal piece that connects the the ignition switch to the linkage rod that accuates the rod running down the steering column. The problem is I cant tell how I would replace the part.
I have taken off the cowl at the dash and busted off the plastic piece that contains the "key releaser". However the steering whell doesnt want to seem to come off and I'm not sure it needs to.
Can anyone offer insight into how to go about removing the necessary parts in order to repair this part? Or can anyone offer a temporary work around?
I can mannually pull the linkage rod to get proper key swithc position but I can figure out how to get the starter to engage.
Any help is appreciated.
Thanks
hiljak is offline
post #2 of 11 Old 03-04-2013, 11:15 AM Thread Starter
hiljak
1982 CJ7
Anyone got any ideas of a work around solution to get teh starter to engage .....or what it would take to do a complete and proper fix?
hiljak is offline
post #3 of 11 Old 03-04-2013, 11:52 AM
Megaram
For a quick fix, you could take the two wires out of the column connector and wire in a push button to pull in the solenoid. Shouldn't be to much trouble and fetches back on the road til you can resolve the broken piece issue. Good luck.
Megaram is offline
post #4 of 11 Old 03-04-2013, 03:28 PM Thread Starter
hiljak
1982 CJ7
Thanks^^^^ Any idea which two wires? What color are the two I need?
hiljak is offline
post #5 of 11 Old 03-04-2013, 03:31 PM
Megaram
Ugh, I don't have a good schematic but I'm sure someone on the forum does. If worse comes to worse you can trace them back from the starter solenoid. I saw a jeep factory service manual online somewhere with a whole slew of schematics. Try a google search maybe.
Megaram is offline
post #6 of 11 Old 03-04-2013, 03:37 PM
Megaram
These look like they'll help
12v to the lt. blue wire through a push button switch.
Megaram is offline
post #7 of 11 Old 03-04-2013, 03:46 PM Thread Starter
hiljak
1982 CJ7
I guess you're right. I just need to wire a switch/button to jump the solenoid over. I would just accuate the key switch then hit the toggle/button. Ok, fair enough. I will try that once I get a chance over the next couple of days. I'll look for a more permenant fix when I tire of the work-around.
Thanks for your help.
hiljak is offline
post #8 of 11 Old 03-04-2013, 04:30 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
You can also buy a remote starter from your local auto parts store for about $10.
Here's one at Summit for $11.95
Matt
Matt1981CJ7 is online now
post #9 of 11 Old 03-04-2013, 05:34 PM
Megaram
No prob,with a push button starter your jeep will be like one of these modern luxury cars........haha!
Megaram is offline
post #10 of 11 Old 03-04-2013, 06:11 PM
248107
1983 CJ7
Inside this thread is some links to repairing your column actuator.Also some good info on doing it.
http://www.jeepforum.com/forum/f8/ti...lease-1294496/
248107 is offline
post #11 of 11 Old 03-06-2013, 02:12 PM Thread Starter
hiljak
1982 CJ7
Perfect....thanks for the help and feedback. Much appreciated.
hiljak is offline
